Klystron
About 2 weeks ago I traded in my 11 JSW and bought a 2013 Passat 6MT. From the day I drove it off the lot I noticed a slight pull to the right and called back the next day and made a appointment to get a warranty alignment.
Today they did the alignment and when they put it on the rack the only two things that were out of spec were the right front caster and the right rear toe.
The front right caster is 7.24 with a acceptable range of 7.25 to 8.25
The rear toe was -0.03 with a acceptable range of 0.10 to 0.00
After the alignment everything was centered pretty much center of spec with the exception of the caster. With the left being perfect at 7.40 deg but the right still at 7.24 deg.
When I asked about the caster they said its non adjustable but doesn't cause wear which I understand. My concern why is a brand new car with less than 1,000 miles have its caster out of alignment?
I saw NateM's post http://forums.tdiclub.com/showpost.php?p=3902297&postcount=12 about his Passat and also noticed his right caster was off in the same direction as mine.
So could this be a VW manufacturing issue ?
Is this something to worry about or should I just drive more and worry less ?
