Linda Jantzen
Hi!
I've been lurking here for quite awhile and have read almost all of the postings about the temperature blend door. I have a 2002 New Beetle TDI with about 104K. Here's my problem:
First, I'm a girl. I took my car into the shop about a month ago because the ventilation was either stuck in cold a/c or super hot heat. There was no in between and it couldn't be adjusted with the temp control. I didn't want to take it to the dealer, so I took it to the local import shop that did the timing belt a couple years ago. I told them I thought it was the temp blend door cable. The mechanic asked me if I wanted them to fix what was wrong or what I thought was wrong. Of course, I was annoyed but I complained to the manager and let them work on it.
I was in luck! The problem was the bushings that only cost about $165 to fix. When I picked it up, the a/c was tepid. It was about 76 degrees and the a/c couldn't make the car comfortable. Plus, you still couldn't adjust the temp.
I took it in to the same shop a couple weeks later. I was in luck! It only needed more freon. I was assured that the a/c was now "ice cold." And it only cost $65! I picked it up and the car and the a/c was still tepid. And you still couldn't adjust the temp.
I was going to break down and take it to the dealership but noticed that I was charged $50 to "analyze" the problem. Annoyed, I took it to the same shop and requested that they check the temp blend door like I suggested a month ago. He just called me back. Now, the whole temp blend door assembly needs to be replaced ($400 for the parts, plus about 11 hours labor. $1500 total. Cha-ching!!) How do you know it's not just the cable? Uh....I don't know. You'll need to talk to my mechanic. The same guy that insulted me when I brought the car in? I don't think so.
I'm going to get the car later this afternoon. Here are my questions:
1. Can you tell that the temperature blend door assembly needs to be replaced just by looking at it? Wouldn't you need to take something apart to see? Also, if you can tell by looking at it, why wasn't it noticed in the first place?
2. I live in southeastern Colorado and don't have a great deal of options. Can I risk driving the car 40-45 miles with the "check engine" light on?
3. Does anyone know of an honest VW repair shop in the Colorado Springs area?
Thanks!
Thanks!
