Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
View Poll Results: Should this thread remain stickied?
yes 6 60.00%
No 4 40.00%
Voters: 10. You may not vote on this poll
Old March 3rd, 2017, 14:52   #631
Nevada_TDI
The Bently Biofuels station is still closed. I did some asking around and never got a specific answer. They are still providing their wholesale customers as far as I know. They might deliver to you if you have a big enough tank available for your "home heating oil."
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old March 3rd, 2017, 16:06   #632
SFHGolfTDI
SFHGolfTDI's Avatar
Originally Posted by drsven View Post
Do you happen to know if Bently Biofuels is still in business? Last time I filled up at the Minden pumps was a few years back while visiting family in Carson Valley.
They were sold to Pacific Biodiesel a couple of years ago: http://www.recordcourier.com/news/bu...ntly-biofuels/
I think they still produce biodiesel there, but the retail operation, as you've seen, has been shut down.
Front end swap (Jolf), GTI tails, heated GTI leathers, GLI steering wheel, aluminum trim, center console w/cupholders, homelink visor, SGII, front/rear fogs, remote windows, 35% ceramic tint, Q5/Touareg rear wiper, roof rack, vented, PD engine cover mounts, Fumoto F106SW, panzer skid, Bilstein HDs, mudflaps, Conti PureContacts, custom 2" class II hitch. Kerma tuning. VCDS available (K-II USB).
SFHGolfTDI is offline   Reply With Quote
Old March 3rd, 2017, 16:45   #633
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Thanks for the info folks.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old March 6th, 2017, 12:12   #634
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
Arrow
anybody else catch motorweek this week showing off, highlighting in the clean cities segment Plainfield VT.'s "Black Bear Biodiesel"?? the only public access in VT to B100....
It showed an at the pump sign for B100 @ $2.299........
More diesels than I can list
rotarykid is offline   Reply With Quote
Old March 23rd, 2017, 06:38   #635
BlueJay83
BlueJay83's Avatar
MikeS,
Just curious if you still have the GreaseCar kit?
I'm in Wilmington, DE.
Thanks,
Brad
BlueJay83 is offline   Reply With Quote
Old June 16th, 2017, 18:19   #636
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Interesting contact listing for Black Bear: malloybiodiesel at geemail dot com. Hmmmm, I wonder if this is an off-shoot of T H Malloy... So I look on Malloy's web site and I see their pump pricing no longer lists B50 nor B99. What?
I still have 20 gallons in the garage, and an indicated near-full tank in the car, so I'm good for a while, but I'll still call T H Malloy to check if they still carry my desired B99 (or higher).
If not, then either Newport Biodiesel, or Black Bear.
If the quantity of carbonic acid increases in geometric progression,
the augmentation of the temperature will increase nearly in arithmetic progression.
Svante Arrhenius 1896
Cogito ergo soy (I think, therefore: Biodiesel)
Lug_Nut is offline   Reply With Quote
Old August 1st, 2017, 17:48   #637
Lug_Nut
Lug_Nut's Avatar
THMalloy has updated their site and pump pricing. On-road, tax-paid, B99 is $2.089 gal. (1st Aug. 2017). That's just $0.01 more per gal. than their off-road, dyed, ULSD.
On the down side, Newport Biodiesel is no longer selling retail.
<edit> so I'm scrolling back to look for B99+ retailers in the mid-atlantic and I came to post #609 from 2015. THMalloy was retailing B99 at @2.799!?! <end edit>
Old September 2nd, 2017, 17:01   #638
Lug_Nut
Lug_Nut's Avatar
Black Bear is run by a Malloy family member, but is not part of T. H. Malloy.
Gas-Up in Asheville still has B99 bio, but the other retailer in Sylva NC has ceased carrying bio.
Old March 24th, 2018, 21:04   #639
luminousgypsy
I know that Propel's Diesel HPR does not contain biodiesel but it's made from renewable biomass (98%!!) and is available in California in a few locations. Also it meets all specifications so can be used in all diesel engines.
I feel like it should be added to the list.
https://dieselhpr.com/learn-more
luminousgypsy is offline   Reply With Quote
Old March 25th, 2018, 16:27   #640
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Baltimore Biodiesel currently has B50 winter blend at $3.35/gallon.
-George Bernard Shaw
Old September 18th, 2018, 02:35   #641
Mattybulldog
TDI(s): 2004 jetta
Bio diesel is horrible for your car DONT USE IT
Mattybulldog is offline   Reply With Quote
Old September 18th, 2018, 06:16   #642
atc98002
atc98002's Avatar
That's a rather bold and unsubstantiated claim. It completely depends on the year and model of the engine. Yes, the common rail engines are not good with anything over B-20, and really don't like over B-5 long term. But the older TDIs are much more tolerant. Again, specific model engines tolerate it better than others. If I had an older TDI, say 2002 or older, I wouldn't have any problem using BD. And of course, when you get to the older indirect injection engiines, they run on almost anything that burns and BD is great in them.
2018 Subaru Outback 3.6R Touring
2005 Ram 1500
2013 VW GTI: daughter
2010 Routan gone, replaced with 2018 Pacifica Hybrid: other daughter has 3 kids
atc98002 is offline   Reply With Quote
Old September 20th, 2018, 15:33   #643
rotarykid
rotarykid's Avatar
Arrow
We on the front range are down to only one place left I know of to get BD20 or BD100...SHOCO Oil off of US 85 north of I-270 in commerce city...
While B20 is only running as much as prem, gas there.....B100 is over ~$5 a gal...I usually go up there getting 4 or 5 5.5 gal containers to mix in over time to keep the fuel system clean & for the way my 99.5 runs better on it compared to regular D2.....
Old September 25th, 2018, 19:30   #644
Nevada_TDI
I wished 2 heck I had someplace close I could go buy some biodiesel that was remotely close, and wasn't overpriced. I like the idea of running anywhere between B5 and B20 just cuz it's good for the parts that it runs through as a great cleaner and of course the higher lubricity.
_______________
Old September 26th, 2018, 05:14   #645
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
What happened to the place in Minden? I used to fuel up there on my way to Reno. The last time about 5 years ago.
Premium Diesel Locations by State pyankura Fuels & Lubricants 25 March 26th, 2009 09:09
Diesel locations, prices in N.A Jetta_Pilot Ontario 3 July 13th, 2008 20:01
Locations for Methanol, NaOH or KOH, By State Schwrtz27 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 11 June 4th, 2008 13:03
biodiesel locations sailor55 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 August 21st, 2002 08:32
Are radar detectors legal in your State/Province? Sacha General VW Discussion 23 July 20th, 2001 14:14
Page generated in 0.19145 seconds with 14 queries
[Output: 135.08 Kb. compressed to 113.05 Kb. by saving 22.03 Kb. (16.31%)]
