Old July 13th, 2017, 05:16   #1
roni024
Default Driver's door and fuel lock actuators
I just noticed a problem with my 13 Passat. After I start driving I hear a click and the door lock indicator is no longer lit and the driver's door (unsure of others) is unlocked. Also, when I use the fob to lock the doors the driver's will sometimes not lock. I suspect the driver's door lock actuator to be faulty and am sourcing a replacement. However, in checking all the other doors while the car is "locked" I noticed the fuel flap does not lock.
I saw a post from OilHammer that said (speaking of the fuel lock - shortened for pertinence):
"The little motor in there fails. It is pretty common now. Same piece the Tiguan uses.
The little motor just allows the pop out spring release to work or not, and it only allows it to work if the driver's door is unlocked. You can take it apart and disable it (so it always works regardless of the lock status of the driver's door)."
My question is, does the fuel lock rely so heavily upon the driver's door lock that having a faulty driver's lock actuator alone can cause locking issues with the fuel flap, or do you suspect I have two separate issues?
roni024 is offline   Reply With Quote
Old July 13th, 2017, 08:49   #2
740GLE
It probably failed unlocked long time ago and you are now just noticing. Just be glad it didn't fail locked with you standing at the pump.
Useless electronic garbage just waiting to break, disconnect the connector to the motor, its behind the carpet inside the trunk and be glad you'll never have to worry about it failing locked at 1am and you are running on fumes.
with Diesel being $2.05 at my local station this morning, who's siphoning fuel these days? Locking fuel door is just as useless as security lug bolts <end old man rant (at 33 and bald can I consider myself and old man)>
As for the door locks, its a known issue and you can open up the mechanism and clean the carbon off the cheap motor, or give VW parts $130 for a whole new mechanism. Therse a nice thread in the MKV folder, not sure if it's the same exact part but if your time is free, its a cheap fix.
Old July 13th, 2017, 10:21   #3
roni024
I think I'm with you on leaving the fuel flap lock inoperable. The OilHammer quote I truncated actually went on to say the fuel lock actuator is cycled every time you lock and unlock the doors and tends to wear the part out quickly. Like you said, it would suck to have it freeze in the locked position when it matters.
From what I've read on these forums, I think the MkV and MkVI/NMS door lock actuators are different in the sense that the newer ones cannot be disassembled easily. Please, someone tell me I'm wrong so I can save $100 or so.
Old July 13th, 2017, 11:19   #4
VernK
Originally Posted by 740GLE View Post
…with Diesel being $2.05 at my local station this morning, who's siphoning fuel these days?
The same people that were siphoning it at 35˘.
Yours
Vern
VernK is offline   Reply With Quote
Old July 13th, 2017, 11:33   #5
tadawson
Frankly, I'd be more concerned about some mental midget dumping something in these days . . .
tadawson is online now   Reply With Quote
Old July 13th, 2017, 11:50   #6
roni024
Good point!
Old July 13th, 2017, 12:16   #7
740GLE
Then its time to reassess where you socialize, live, work.
But granted, no one can truly escape those that have defied Drawin.
Old July 13th, 2017, 12:17   #8
tadawson
Planet earth? Stupid appears to have no boundaries these days . . .
We live in a very nice neighborhood, but that didn't stop some jerk from spray painting a car in the drive 12 years or so ago, or the tagging on my fence 2 years ago. Scum often travels to 'play' . . . I've also lived in very rural towns (pop 5k) and still not immune. Now, with all the nuts and a TDI, seems like a bit of a target to the particularly deranged . . .
Old July 13th, 2017, 21:26   #9
jrm
Fuel Economy: 42/52
I have a few friends who got there TDI keyed- 1 of them drove his coal rolling Cummins while it was in the shop getting painted Lots of crazy aroud my work as well- its sad though as I can park my old civic anywhere, not the slightest ding over 10 years. park the TDI in the same crappy area once and boom, dented from a sidewalk fight after a thief was tackled beside my car.
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old August 30th, 2017, 05:41   #10
roni024
I wanted to post an update on my door lock actuator problem.
I decided to try and lubricate the mechanism before possibly replacing it. I loaded the actuator assembly up with spray silicone through the opening for the door release arm at the bottom of the actuator assembly, as well as some small holes I drilled in other areas to inject the silicone spray. It works beautifully! I'm not too concerned about moisture getting in the holes I drilled (shallowly, BTW) since the actuator assembly is not sealed anyway.
Caveat: make sure you route the cable for the door handle on the same side of the support pillar it came out of. Otherwise, you may be about to get on the highway, put your window down a bit, have your door pop open and your car DING at you, and have to hold your door shut until you get home, call your boss and tell them you'll be late to work, remove the door panel and realize how much of an idiot you are since the window is hitting the latch release cable. Not that it happened to me, or anything...
Old August 30th, 2017, 06:14   #11
thundershorts
I had a failure of my 2013 drivers door latch and found it was a Mexico produced item. It was replaced with a Czech Republic unit. This problem has been reported on quite a few 2013's so perhaps VW knew the Mex units were not too good. I reported mine to nhtsa as mine prevented the door from latching.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Door lock actuator 2006 Jetta driver door EBay fail, where to get a good one? sptsailing VW MKV-A5 Golf/Jettas 5 December 6th, 2016 05:11
MKIV OEM Door lock / latch assembly (Driver's Door) slyk Private TDI Items for Sale/Wanted 1 January 4th, 2016 09:11
Good place to buy door lock actuators Speardog VW MKIV-A4 TDIs (VE and PD) 5 July 17th, 2015 02:43
wtb: door lock actuators for 2004 Passat prometheum Private TDI Items for Sale/Wanted 2 April 16th, 2015 17:53
driver door lock actuator not holding in lock? RuneTDI VW MKIII-A3/B4 TDIs 5 September 4th, 2010 20:17
Page generated in 0.14559 seconds with 11 queries
[Output: 102.72 Kb. compressed to 86.90 Kb. by saving 15.83 Kb. (15.41%)]
