Old July 7th, 2017, 21:16   #1
New Mickey
The user formerly known as mickey
TDI(s): 2015 Passat
Default Like a virgin
Deja vu! I can remember exploring under the hood of the Evil Beetle trying to figure out what all the weird lumpy bits were. Now I'm going through it again. It's kind of fun!
First of all, I figured out how to take the plastic cover off the engine. (No more screws. Rubber grommets.) Then I quickly found the fuel filter. But it took me a minute to figure out what the aluminum box was....AIR TO WATER INTERCOOLER! Who knew? (Not me.)
Questions:
1. Where did they hide the oil filter?
2. Has anyone used a Topsider to suck out the oil from a 2.0 CR TDI? Can a tube reach all the way down to the bottom of the sump?
3. What's the Flapper Valve for? Does it involve Betty Boop?
And an important conclusion: I'm too old and non-bendy to work on this thing, so I hope it's reliable. The under-hood environment is tighter than a 9 year-old nun. Does NOT look like fun to work on.
-mickey
New Mickey is offline   Reply With Quote
Old July 7th, 2017, 22:07   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Welcome back, mickey
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old July 7th, 2017, 22:17   #3
jrm
Fuel Economy: 42/52
I also come from the pre TDI Era as well, grew up swapping .75 5th gears into 1.6 rabbits and golf's to get that sweet 55+ MPG. The NMS Passat is a great ride, not as tough as our old 1.9's and such but overall quite good- you will have fun learning all about it- even the glow plugs can read real time combustion pressures! The thing is super smart, it has both intake and exhaust butterfly valves so it coasts better than a gasser- until you touch the brakes- as soon as the brake lights activate the ECM knows you want braking, it will drop a gear and open the intake and exhaust valves giving you the classic diesel compression braking as needed, just a sweet ride and once you understand what causes what (brake lights) you can really hyper mile these things!
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old July 8th, 2017, 00:13   #4
New Mickey
TDI(s): 2015 Passat
I've noticed the DSG drops a gear when the car's speed exceeds what you've set with the cruise control whether you brake or not. Actually I wish it was more aggressive about holding the speed down. My much-lamented 2015 F-15 was brilliant that way. It would drop as many gears as necessary to maintain the set speed, but if I wanted to "hypermile" I had but to cancel the cruise control and it would stay in top gear.
The Passat works basically the same way, but never seems to drop more than a single gear to maintain your set speed. I find myself using the Tiptronic slot for mountain descents. There's also a huge step in gear ratio between 2nd and 3rd so I've learned not to drop all the way to 2nd unless I'm down to 2000 RPMs or less in 3rd.
Diesels don't "compression brake" worth a wet slap, because they have no throttle valves. The energy used to compress the air pushes the piston back down again, so there is no net braking effect except for internal friction. That's why "Jake brakes" and other schemes are needed.
I didn't know the 2.0 CR did that. I need to study up.
-mickey
Old July 8th, 2017, 00:36   #5
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
The exhaust flapper is active during start ups and soot trap regens.
When you start the car up and drive off, within the first 1 to 3 miles the flapper will restrict the exhaust flow to raise EGT. This is to warm up the catalyst systems ASAP. Usual EGT will be around 1100F to get the DPF temp to around ~800F. This warm up mode lasts around 1 minute. You have to be in 3rd gear or higher for the ECU to go into catalyst warm-up mode
When the soot trap sensors detect a high differential the ECU will call for a soot trap regen. The flapper will again restrict exhaust flow to get the EGT high enough to burn off the soot. Fuel injection is retarded to allow raw fuel into the exhaust and get the DPF very hot very fast. During uninterrupted highway driving a typical regen will last around 10 miles. During stop & go city driving a typical regen lasts around 6 miles. The shorter regen time does not mean a better regen. It means the ECU detected the interruptions and called it quits early when the DPF regen was close enough. The more highway driving with uninterrupted regens means fewer regens. Fewer regens means less ash build up in the DPF and it will last longer. During a regen the EGT will drift around from 950F to 1350F and the DPF temps will get as high as 1150F.
There are 3 ways to monitor all this. Methods listed from the easiest/cheapest to the most involved/expensive.
1. get a OBD-II Bluetooth dongle and download an OBD-II app for your smart phone. Plug the dongle into the OBD-II port and set up your phone bluetooth and app. While this is the cheapest and easiest to use, the downside is that it ties up your phone. For constant monitoring some owners get an old obsolete smart phone and leave it plugged in all the time. A bluetooth OBD-II dongle is usually less than $20. Here is a thread on OBD-II dongles. http://forums.tdiclub.com/showthread.php?t=479014
2. Buy a Scangauge-II. Prices are all over the place from $100 to $150 so watch for a sale. Here is the link for setting up the Scangauge-II. http://forums.tdiclub.com/showthread.php?t=360498
3. Get a VCDS cable (formally known as VAGCOM). The bad; expensive, lots of reading to learn how to use it. The good; use for diagnosing just about anything, data-logging, can be used with a cheap windows laptop or tablet. With VCDS you can force a regen at your convenience. Convenience meaning you are monitoring the DPF differential and when you are getting close you can force a regen when you know you have at least 10 miles of steady driving, like on the highway on cruise control. The ODB Scanner forum is your friend here.
Some other trivia for you: The 2012-2014 Passat TDIs use the CRKA engine. The 2015 Passat TDI uses the CVCA engine. Not much interchanges between the engines. On the CVCA the intercooler and intake manifold are one part. On the older CRKA they are two separate parts.
The CRKA and the CVCA catalyst systems are completely different designs although they do exactly the same thing.
The oil filter on the CVCA is a canister type facing down along side the engine, similar to the 2.5L gasser. You're going to have to get under the engine to change the oil filter. The oil filter on the CRKA is similar to the old ALH engines, filter housing facing up. Lots of members use a Topsider.
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old July 8th, 2017, 09:42   #6
compu_85
Gadget Guy
compu_85's Avatar
I'm not sure about the 15s, but the 12-14s can be *very* tricky to use a topsider on due to how the oil pan is arranged. It's easy for the suction tube to get stuck in a "redirection" tube mounted below the balance shaft. Use only a small, metal reinforced tube!
What flapper are you talking about? The intake throttle? Exhaust throttle? Warm up flap on the airbox?
Present:
2013 Fiat 500e. 18,000 miles. Almost 100 miles per charge!
Past:
Old July 10th, 2017, 09:34   #7
740GLE
-mickey
You should drive a 2012-2014 DSG passat, its a different transmission gearing as well as control unit. It loves to down shift on hills and you'll be in 3rd gear doing 55-60 down a hill if you keep a light foot on the brake, I found it didn't really slow you down and just seemed to make more noise.
I haven't driven our '15 enough but did notice its not as jumpy to downshift.
Old July 10th, 2017, 09:37   #8
740GLE
Also the oil filter is accessed from under the car, and it will dribble so catch can is needed. So if you're under there, is there a point to the top side? Maybe avoid any additional spills?
Old July 10th, 2017, 11:01   #9
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yes, you'll need to get under the car anyway. I gently move a harness off of its stay and position aside to make for less mess. The longer you can let the drain plug drain the better, too. Not sure which filter is better, to be honest. The CKRA is worse than the CBEA/CJAA in that it is tighter in there and it uses a plastic housing instead of aluminum. I suspect that could be a problem in years to come.
Of course by then there will be so few CKRA cars left on the road, we won't notice.
oilhammer
www.cardocautomotive.com
Old July 10th, 2017, 12:30   #10
KERMA
KERMA's Avatar
Also, the Polar FIS works with the passats. Super cool, turns your MFA into gages.
VCDS needs to be one of the hex+can or newer ones that use the "smart dongle". The older cables won't work.
Interesting what BK said about regens but FWIW those cars base their regens on the internal model not the measured D/P.
Mickey come by sometime, I can give you a guided tour of your car's stuff if you want. And yes your car does have throttle(s).
HP is for show, TQ is for go.
celebrating 15 years of: http://www.kermatdi.com
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old July 11th, 2017, 05:39   #11
740GLE
I hated pulling the oil filter from the CKRA, the wire loom could only be moved so far out of the way to wiggle the filter/cap. Eventually i loosened the HP egr tube enough to gain access.
As for the CKRA being on the road I hope the "fix" will provide enough incentive for VWoA to resell them and keep them going.
I'd love to snag a '12 Passat SE manual as a beater car to keep the miles off the Alltrack.
In a year or so I'll let you know how I feel about the new CRVA
Old July 11th, 2017, 06:33   #12
Rico567
<snip>
These cars seem to come with things ever so slightly different in a way that allows the filter & cap to be "angled" to the right and forward out of the housing. We got lucky with our '13 Passat, as all it takes is to remove those three T30 screws on top, set the plastic bracket aside and ease that tube toward the front of the car to then maneuver the cap & old filter up and out. There is no excuse for any of it, of course. It wouldn't have required any genius engineering to make it an easy matter to do the change. But the engineers who designed it didn't necessarily plan on actually doing any changes themselves. Access to that DSG filter is a different matter, but at least it only has to be done every 40K....
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is online now   Reply With Quote
Old July 11th, 2017, 06:46   #13
roni024
FWIW, on my 2013 Passat the DSG filter is accessed by removing the air-box and snorkel (disassembly of air box not required), battery, and battery tray. 24mm socket gets the filter cap off. I just changed my fluid Friday so it's fresh in my mind.
roni024 is offline   Reply With Quote
Old July 11th, 2017, 10:24   #14
Rico567
Yeah, that's pretty much what I did for the 40K a year ago March. I laid it all out in this: http://forums.tdiclub.com/showthread.php?t=457823
I found the removal of the battery tray to be a bit challenging, although not as much as trying to replace the battery clamp. All of this doesn't mean it couldn't be engineered to make the DSG service easier, but I certainly concede that probably would be harder than just creating a smidge more room to get the CKRA engine oil filter cap up & out more easily.
- Adam Savage
Old July 11th, 2017, 18:40   #15
BKmetz
Administrator
BKmetz's Avatar
I've watched dozens of regens on my Scangauge and if there is one thing that is consistent, it's how the ECU determines when a regen is needed is completely inconsistent. I've had as many as 3 short regens within 100 miles of each other and I've gone almost 2 tanks of fuel (~1600 miles) between regens. I'm sure there are several parameters the ECU is looking at. The only common denominator that I can think of is how much soot has collected in the DPF. 'internal model' is an interesting term. Can you expand on that?
Yes, you'll need to get under the car anyway. I gently move a harness off of its stay and position aside to make for less mess. The longer you can let the drain plug drain the better, too. Not sure which filter is better, to be honest. won't notice.
I pack some paper towels around the oil filter and wire loom. Then I unscrew the cap and pop it up, not off, and let the oil drain down a while before I remove the oil filter. A blast of brake cleaner takes care of any mess I made when I'm done. It took me a while but I figured out the perfect angle to drop the clean filter back into the filter housing. That plastic center piece that is part of the cap and sticks out a bit from below the actual filter has to be perfectly aimed to hit the hole in the filter housing and there is no room to wiggle it around.
All in all, I would rather change oil in a CRKA over a 1Z or AHU. No possible way to change one of them without making a mess.
TDI virgin Patmine TDI 101 0 June 14th, 2013 19:28
TDI Virgin! TDIgrl Fuels & Lubricants 55 December 27th, 2011 23:09
biodiesel virgin! dubburke Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 3 April 28th, 2004 10:40
bio- virgin tobsav Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 13 July 4th, 2003 06:01
Venting Virgin sprattyken TDI Fuel Economy 0 March 9th, 2001 17:14
Page generated in 0.17975 seconds with 11 queries
[Output: 143.51 Kb. compressed to 121.63 Kb. by saving 21.88 Kb. (15.24%)]
