Old June 30th, 2017, 08:59   #1
mirage2521
Default 2015 Oil Temp
This is my first car with an oil temp indicator. What is the average oil temp you guys are seeing. How high is too high?
Diesels past and present 2015 Passat TDI SEL, 2013 JSW TDI, 2010 Jetta TDI, MB 300D
2003 Ford F250 6.0l Power Stroke
mirage2521 is offline   Reply With Quote
Old June 30th, 2017, 09:33   #2
rustycat
I haven't checked it too much, but I'm thinking 212 degrees.
rustycat is offline   Reply With Quote
Old June 30th, 2017, 09:41   #3
ZippyNH
With modern oils, and coolant to oil coolers, don't worry, drive more.
Guess if you are towing and you see it spike, then slow down.....
The guages are more about waiting till you see it move a bit on a cold day before you drive it hard.
ZippyNH is offline   Reply With Quote
Old June 30th, 2017, 10:07   #4
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
With the oil-to-coolant heat exchanger, I would expect oil temperature to follow coolant temperature within about 20 degrees Fahrenheit.
Trusted TDI Mechanics Map || TDIClub Chat
Old June 30th, 2017, 11:07   #5
mirage2521
Oh I drive more, my 2010 Jetta has 305,000 miles. The brand new Passat is running about 217' oil temp. Just wandering what the norm was.
Old June 30th, 2017, 12:28   #6
Skimax
Ours varies from ~200 to 216F, the highest I've seen so far
Max
Skimax is offline   Reply With Quote
Old June 30th, 2017, 14:36   #7
TurboDieselPoint
I've seen nearly 230F on our 2015 SEL driving rapidly mid-regen.
Run the right oil (5W30 507.00 spec), keep your coolant properly maintained, and never worry about oil temp.
TurboDieselPoint
TurboDieselPoint is offline   Reply With Quote
Old June 30th, 2017, 19:27   #8
jrm
Fuel Economy: 42/52
200's is nothing, seen my air cooled bikes reach 400F in full throttle slow trails on hot days- amsoil never sludged up- ever! The bikes wont idle as I lost valve clearance but run perfect again as soon as I shoot down a long stretch and get some air across the fins
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old July 5th, 2017, 04:32   #9
740GLE
223 is pretty common on the Alltrack and '15 Passat.
BTW I think the oil cooler is also there to get the oil up to temp a lot quicker.
Old July 6th, 2017, 09:17   #10
Good Ol' Boy
VeeDubTDI's Avatar
Yep! It works both ways.
Old July 6th, 2017, 09:32   #11
rustycat
I've been paying somewhat closer attention to the oil temp on the 15 EA288 and am very surprised on much and rapidly it changes temp by a few degrees.
Old July 6th, 2017, 09:46   #12
ZippyNH
Remember, the ea-288 has what is effectively a multi-stage cooling system to help it warm up faster, them limit heatloss to improve efficiency...even had grill shutters on the Jetta.
Then you add the transmission (DSG) and oil coolers that are looped into to coolant loop, and the fluids all warm up to their optimal temps very fast.
Really an engineering marvel. Much more like the type of engineering I see on planes (((just look at all the extra tubing, etc, reminds me of many turbo-prop and jet engine in both complexity and density) than on cars in many ways.
2015 Jetta TDI SE, Silk Blue
previous-2005 MINI Cooper S, tuned and modded to 200+ HP
Old July 7th, 2017, 05:00   #13
740GLE
Drive a gen3 1.8T TSI and compare the warm up time of the TDI and you'd hardly say it warms up "fast". In about 2 min and 1/2 mile the TSI has coolant at 200F. Screaming hot air out of the vents in 1 mile.
The 288 are faster at heating up than previous CR diesels, yeah, but I wouldn't say its fast.
Old July 7th, 2017, 05:18   #14
ZippyNH
A gas engine is a gas engine ..those have been like that for decades...glad you have discovered it.
Talking about diesel here...hence the TDIclub...
Now go burn some oil on a drive a redeem yourself!!
2015 TDI seems low on oil at 6600 mi, what oil to top off with? Cutandthrust VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 8 January 30th, 2016 19:12
Boost/Oil PSI/Oil Temp gauge isntall in CR TDi Mitternacht VW MKV-A5 Golf/Jettas 4 January 18th, 2015 10:34
Oil Pressure/Temp Gauge at Turbo Oil Feed Line? arne487 Upgrades (non TDI Engine related) 9 September 25th, 2012 01:27
Where to install McNally oil press/temp on BEW with bypass oil filter coalminer16 TDI 101 5 February 22nd, 2011 23:57
oil drain plug -> VDO oil temp sender dkuster VW MKIV-A4 TDIs (VE and PD) 10 March 31st, 2003 07:33
Page generated in 0.17556 seconds with 11 queries
[Output: 118.92 Kb. compressed to 99.16 Kb. by saving 19.76 Kb. (16.62%)]
