Old June 29th, 2017, 11:32   #1
jw4free
Default 900 mile Club
First 900+ mile tank.
901.1 Miles.
It took 17.946 gallons, but I'm not convinced that it filled completely. The next fillup will confirm.
Drove about 20 miles beyond "Range: 0 miles".
Not too bad, just doing the daily 75 mile round trip commute, no A/C windows rolled down.
jw4free is offline   Reply With Quote
Old June 29th, 2017, 16:21   #2
therabbittree
therabbittree's Avatar
TDI(s): B4 passat
Chancing fuel system to see miles on display . Not worth it
'96 Passat TDI wagon, 1982 Jetta Coupe tdi swap project, 2000 Excursion 4x4, 12v cummins, G56, \x/ hillfolk
therabbittree is offline   Reply With Quote
Old June 29th, 2017, 19:58   #3
jw4free
While your response is anecdotal and entertaining, it lacks relevance to the first post and is without precedent.
Old June 29th, 2017, 21:24   #4
jrm
Fuel Economy: 42/52
Dude, have you seen what a failed HPFP can do to the entire fuel system, $4K in a millisecond
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old June 30th, 2017, 05:47   #5
740GLE
Don't listen to them, I applaud your feat of driving 20 miles past zero! You prob could have gone 20 extra more!
Most we've done on the 2012 was 800 or so. 650 was the most on the 'ol jetta
Old June 30th, 2017, 07:16   #6
therabbittree
TDI(s): B4 passat
Lol really , the fuel system is cooled by fuel. The bottom of the tank has less fuel . Equals more heat
Old June 30th, 2017, 09:30   #7
740GLE
and he survives to drive on!
Old June 30th, 2017, 09:36   #8
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
An impressive feat. I've found 800 miles a difficult milestone to surpass, but I also can't manage to keep it below 65 MPH for that many consecutive miles.
Trusted TDI Mechanics Map || TDIClub Chat
Old June 30th, 2017, 10:40   #9
jw4free
Thanks all.
I drive slow in the slow lane, my commute has 3miles of warm-up city driving with a few stop lights, then a moderate speed increase to 55, highway at 65 (58-63 my speed), slow up hills fast down hills (if you could consider the elevation changes in Kansas and Missouri hills). Off the highway 1 mile and I'm at work. The route is ideal.
The CKRA responds well to high temperatures. This 90 plus temps help a lot. I just roll the windows down a bit, crank the fan, and leave off the A/C.
Most days no wind in the am, Then a strong wind from the south for my Northwestern commute. Also ideal.
It's still not easy, I've wimped out so many times.
Old July 2nd, 2017, 06:03   #10
Skimax
If I filled our old B4 Variant to the top including the 6 gal expansion tank by trickling the fuel in by holding down the vent button It would go well over 1100 miles on a tank,
I miss that wagon!
Max
Skimax is online now   Reply With Quote
Old July 2nd, 2017, 06:11   #11
mirage2521
Its not anecdotal and seems rather relevant to me. As far as precedence, anyone with any mechanical knowledge understands that a low tolerance high pressure pump that using its own pumping medium for internal lubrication should not ever be run dry. Diesel mechanics 101.
Diesels past and present 2015 Passat TDI SEL, 2013 JSW TDI, 2010 Jetta TDI, MB 300D
2003 Ford F250 6.0l Power Stroke
mirage2521 is offline   Reply With Quote
Old July 3rd, 2017, 00:49   #12
MyAvocation
MyAvocation's Avatar
Urban legend, if referring to lift pump.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old July 3rd, 2017, 06:06   #13
740GLE
so you're saying I shouldn't have installed my fuel AC system? I heard from a guy that if fuel isn't under 60F the HPFP blows up. That's why I always fill up in the morning while the ground temps are the lowest.
Old July 3rd, 2017, 18:30   #14
Rico567
You are my hero for today.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old July 3rd, 2017, 21:35   #15
jrm
Fuel Economy: 42/52
4:09 https://www.youtube.com/watch?v=sHUxDHJ9HIs
60 MPG / 900 Mile Club / 1000 Mile Club aggiegrad TDI Fuel Economy 625 November 15th, 2016 09:48
900 mile club? madcowintucson TDI Fuel Economy 3 July 8th, 2012 03:41
900 mile club Lightflyer1 VW MKV-A5 Golf/Jettas 20 April 29th, 2011 14:32
900 Mile Club Karl Roenick TDI Fuel Economy 69 May 30th, 2004 18:26
Page generated in 0.16669 seconds with 11 queries
[Output: 126.24 Kb. compressed to 104.48 Kb. by saving 21.76 Kb. (17.24%)]
