Old July 2nd, 2017, 07:03   #16
Mark_J
"The late injection for the DPF is not burned in the cylinder". I'm confused, isn't the DPF injected quite a ways down stream of the engine in the exhaust pipe before the catalyst, so how would it get into the cylinder? Are you talking about the piston cylinder or something else?
Mark_J is offline   Reply With Quote
Old July 2nd, 2017, 07:44   #17
tdiatlast
Originally Posted by rustycat View Post
Yup, our 13 was rock steady on the oil level as well, guess we'll see if the EA288 behaves differently. Again, I couldn't find anything really pointing to an oil dillution characteristic associated with the EA288 while Googling.
Question: If the engine is using (burning) oil at the exact rate of the amount of diluted fuel returned to the sump, wouldn't the oil level stay the same?
Discuss...
(only a UOA would determine this...)
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old July 2nd, 2017, 07:44   #18
jason_
No, during a regen raw fuel, for a microsecond or so, is shot near the end of the cycle, before the valve laps shut, and turbo boost is increased a fuzz to promote high filter Temps to reduce soot to ash.
I believe there's 5 or 6 injection periods per stroke?
One to reduce traditional piston clatter, one for the actual power pushing of the piston, one for regens, and others programmed for who know what else?
14,000# of fuel pressure and fast cycle injectors makes for a lot of programming fun...
But there always is the possibility of cylinder wash and fuel getting past the rings. Engine to engine comparisons sometimes people get an outstanding cast of a block and piston ring wear , and very little fuel gets into the oil.
I had a small block Gm that kept turning into and oil burner. Walls would disappear and the rings looked brand now. Bored and sleeved it, and still going strong. Just pulled a 15ton loaded trailer with it, 380,000 miles on those sleeves...
Sent from my One using Tapatalk
jason_ is offline   Reply With Quote
Old July 2nd, 2017, 08:07   #19
turbobrick240
turbobrick240's Avatar
Try doubling that. I would prefer a dedicated injector downstream of the turbo to post injection into the cylinders. Though I also never had any dilution issues.
Old July 2nd, 2017, 08:50   #20
jason_
Vcds on the 09 never went past 12000. Maybe it's changed on later models?
Old July 2nd, 2017, 14:13   #21
tadawson
Some diesels use downstream injectors, others (the TDI and Cummins I know for certain) use late injection on the main injectors during exhaust instead . . .
tadawson is offline   Reply With Quote
Old July 2nd, 2017, 21:04   #22
Mark_J
Got it, I thought they were talking about the DEF injection, not injecting the diesel.
Old July 3rd, 2017, 20:13   #23
Locoelectrician
Someone explain this to me please. The hierarchy is, egt, cat, and then dpf, in the exhaust stream. How can my egt and dpf temps be at 1200, while the cat is at 800 during a regen? I’m struggling to understand how the two ends of the system can be at 1200 while the middle is at 800.
Locoelectrician is offline   Reply With Quote
Old July 3rd, 2017, 20:27   #24
turbobrick240
The exhaust gasses cool as they leave the manifold. When they reach the dpf, the post injection fuel vapors (active regen), and trapped soot (all regens) combust and raise the exhaust temps again.
Old July 3rd, 2017, 20:30   #25
Locoelectrician
But isnít post manifold pre turbo, aka egt? How does it cool post turbo (cat)and then reheat in the dpf?
Old July 3rd, 2017, 21:03   #26
turbobrick240
Originally Posted by Locoelectrician View Post
But isn’t post manifold pre turbo, aka egt? How does it cool post turbo (cat)and then reheat in the dpf?
EGTstands for exhaust gas temperature. There are three egt sensors at different locations in the exhaust path. The manifold and turbo are integrated into one unit on these cars. It is reheated in the dpf due to the regen fuel and soot combusting there.
Old July 4th, 2017, 05:45   #27
Locoelectrician
I understand that, and am monitoring all 3. Just doesn’t make sense how the first and last can be hotter than the second. EGT is pre turbo, CAT is post turbo, pre cat, and DPF is obviously the DPF which is last in line. If fuel were sprayed directly into the DPF it would make more sense. Anyways, not the end of the world, was just trying to better understand.
Old July 4th, 2017, 06:06   #28
turbobrick240
It makes perfect sense- you just aren't getting it. Why does a woodstove get hot? Because of the burning fuel inside.
Old July 4th, 2017, 07:08   #29
Locoelectrician
I get that. But if it’s burning before the turbo, and burning in the dpf, then it has to be burning at the cat. My best guess is it has to do with volume and back pressure, but that’s just a guess.
Old July 4th, 2017, 07:25   #30
turbobrick240
It's not burning before the turbo (outside the cylinders). It's burning in the dpf. Along with the trapped soot (carbon).
Oil light flashing while battery light is on 97 VW Jetta Twinn TDI 101 8 January 2nd, 2012 16:07
Low oil pressure, check engine light, glow plug light??? thomps33 VW MKV-A5 Golf/Jettas 2 March 21st, 2011 18:01
Oil light, after change. Plenty of oil. Oil Pump? Chris NF VW MKIV-A4 TDIs (VE and PD) 6 September 1st, 2008 18:37
OIL Light on, but theres oil in there - no power, think turbo is blown, or oil pump Starving_Student Fuels & Lubricants 39 January 28th, 2007 08:06
No Glow Plug Light oil pressure light and no start MNVWMAN VW MKIV-A4 TDIs (VE and PD) 1 August 21st, 2005 18:03
Page generated in 0.15281 seconds with 11 queries
[Output: 124.31 Kb. compressed to 103.91 Kb. by saving 20.39 Kb. (16.41%)]
