Old June 23rd, 2017, 07:40   #16
ZippyNH
Originally Posted by Flyboy777 View Post
I have found the same thing. Nose up helps. When I first got the car I'd fill it up to the first click off and stop but it bugged me that the gas gauge was down an 1/8 from full right from the start. Then I tried a REALLY slow gentle fill and I was able fill it till full on the gauge with it full right up to the top of the neck. That was good as it extended the range to say 1300km but it took a really really long time to fill. Now I fast fill it to the first click off and pause to let the foam die down then fill with really short clicks till the neck is brimming. At 0 range on the MFI readout the most I have ever put in the 70 litre tank is 67 and more usually it is 62 to 65 litres. As far as I can tell 0 range is just as the manual states there is probably a 6- 7 litre reserve which translates to an additional 150 km of range. I don't sweat the 0 range because I know I this. Of course driving into that range raises the spectre of eventually drawing air into the system so probably good to not go to far past 0 range. That way there is enough fuel in the bottom of the tank to keep the pickup covered.
How much lubrication does foaming fuel provide to a hpfp?
Not much. Air is terrible lube...
I'm don't go too low.
I refuel when the low fuel light comes on... sometimes sooner if cheap or I have time.
2015 Jetta TDI SE, Silk Blue
previous-2005 MINI Cooper S, tuned and modded to 200+ HP
ZippyNH is offline   Reply With Quote
Old June 23rd, 2017, 22:04   #17
tdiatlast
I suspect that this is the most valuable post in this thread.
With all the fuel circulating, at a rapid rate (?), I'll bet there is substantial foaming of fuel when the tank gets near empty.
Total speculation on my part, but my OCD analysis of such things tells me I'm right. HAHA!
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old June 23rd, 2017, 23:29   #18
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
In my experience the NMS Passat is as easy to top off than the older models that had the vent valve in the filler neck removed. For those that have one, the nozzle restrictor has not had any effect in filling the fuel tank up to the brim.
I do routinely top off my car up to the the very top of the filler neck. I have kept mileage logs since my first tank with my first TDI, my beloved 97 Passat.
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old June 25th, 2017, 12:47   #19
compu_85
Gadget Guy
compu_85's Avatar
Originally Posted by MichaelB View Post
And how does that make your world and your life better? It's just OCD and they do have medication for that.
Whenever I fill the cars I always fill "to the brim" - as 'dub noted, how else will you get an accurate fuel economy calculation?
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old June 26th, 2017, 05:14   #20
740GLE
On the Alltrack I've given up tracking MPG tank per tank as it has the evap system and don't want to brim it.
A piece of me is missing each time I fill up, knowing that I'm not getting an accurate fill to calculate actual miles/gallon.
Old June 26th, 2017, 06:38   #21
compu_85
Gadget Guy
compu_85's Avatar
Gasoline is different... it doesn't foam up like diesel, so waiting for the pump to click off is a much more consistent measurement.
Old June 26th, 2017, 10:52   #22
jaydhall
MICKEY! I have missed youse!
2012 Passat TDI SE, 99.5 Jetta TDI >350,000 miles
jaydhall is offline   Reply With Quote
Old June 28th, 2017, 05:34   #23
740GLE
Yeah but it clicks off, but I know there's still room!
Fate of Your Beloved TDI after BuyBack gmcjetpilot Dieselgate - VW Group Emission Scandal 31 October 19th, 2016 08:07
Possible Turbo Failure - My Beloved TDI kjprince VW MKIV-A4 TDIs (VE and PD) 11 February 18th, 2014 11:31
Add a 3rd button to a 2-button wagon fob gmenounos VW MKIV-A4 TDIs (VE and PD) 2 March 5th, 2011 18:12
My beloved 1998 Jetta Lifeless please help. jacobssTDI VW MKIII-A3/B4 TDIs 16 December 20th, 2002 10:06
My beloved 1998 Jetta Lifeless please help. jacobssTDI VW MKIV-A4 TDIs (VE and PD) 11 December 4th, 2002 18:55
Page generated in 0.15318 seconds with 11 queries
[Output: 92.60 Kb. compressed to 80.36 Kb. by saving 12.24 Kb. (13.22%)]
