Old June 14th, 2017, 13:59   #1
powerfool
Fuel Economy: 50 mpg
Default No air flow with air conditioner after a few miles
So, I have my 2014 Passat SE... it is a nearly 70k miles now. Last summer we started having an issue with the AC on a trip from Indy to Chicago, and then Chicago to Traverse City, MI, and then back to Indy. Longer drivers, for sure. It would blow cold, and then there was no air flow (everything was still running, including the fan). We let it sit when we got something to eat and we see a huge pool of water (the melted condensation).
We took it in to get serviced and it was low on refrigerant... which makes sense. They tried telling me that it is "normal" to have it low and that some gets "consumed" which is total BS. I told him if that were the case... some politicians would have taken all of our air conditioners by now. Anyhow... it worked fine for a couple of weeks and then started happening again. We took it back assuming they could find the leak this time because of the dye in the filled up refrigerant... and nope.
So, we got into winter time and I wasn't that worried about it because we weren't going to be driving much, but I was concerned about its ability to reduce the moisture when we had defrost on. We didn't have too many issues, though... I imagine that the heat kept it from freezing up and blocking the air flow.
Now that we are back in the warm weather, we took it back. This time... they say that they cannot reproduce it and that the refrigerant is fine. Anyone else have these issues? It isn't even intermittent for me... I can reproduce it pretty much every single time I drive over 10 miles.
Is it possible that the drain for the condensation could be clogged and that is causing an issue? Thanks!
2002 Jetta GLS TDI 5M- Bilstein TC Sports VR6, MOOG Coil Springs
2014 Passat TDI SE DSG - collision avoidance pack, appearance guard, trunk bag hook, and a serious tint job
powerfool is offline   Reply With Quote
Old June 14th, 2017, 14:09   #2
unixb0y
I wondering if the AC Coil is icing up. Maybe because of lack of airflow. When was the cabin air filter last changed?
unixb0y is offline   Reply With Quote
Old June 14th, 2017, 15:06   #3
ZippyNH
Sounds like the drain is clogged...
You need to open it up...
If the coil is submerged, it gonna freeze...and stink.
2015 Jetta TDI SE, Silk Blue
previous-2005 MINI Cooper S, tuned and modded to 200+ HP
ZippyNH is offline   Reply With Quote
Old June 14th, 2017, 16:17   #4
powerfool
Yeah... that was my thought as of today.
Old June 14th, 2017, 16:17   #5
powerfool
It should have been at 60k miles... I let the dealer do the service and it is the last time.
Old June 15th, 2017, 09:25   #6
unixb0y
Here is how you can check the filter
https://www.youtube.com/watch?v=GZx7mCpnr9M
Old June 15th, 2017, 10:19   #7
tadawson
But he says he sees a big puddle (didn't say where, though . . ) when it thaws. This is likelyy classic leak/undercharge, and I suspect that the dealer just blew him off the last time in, since with the newer systems, about the only way to verify charge is to recover/weigh/recharge . . . Pressures just won't cut it any more . . . nor will dyes in the charge, since you can't see everywhere. This needs to be tested with an electronic sniffer - those can detect leak rates under 1 oz per *year*!
tadawson is online now   Reply With Quote
Old June 15th, 2017, 15:50   #8
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
You should be able to view the evaporator temperature in VCDS.
On the Climatronic system, it will regulate compressor load to prevent the evaporator from freezing. I don't know how the Climatic (manual) climate control system functions.
Trusted TDI Mechanics Map || TDIClub Chat
Old June 15th, 2017, 19:06   #9
tadawson
Evap temp isn't the issue - it's glide. The temp on an evaporator is fairly even with a proper charge, but with low charge, all evaporation (cooling) occurs in a small area near the inlet, which promptly freezes, allowing liquid refrigerant to travel farther into the evap, progessively freezing across is. Since the probe only reads one spot, no telling what you will see . . . Likely they would tend to read the outlet side, to ensure adequate refrigerant to cool the entire evap uniformly. If low, outlet likely stays warm, causing the compressor to run at max, and progressively freezing the rest (pretty much the same as a TXV, just controlling flow via the compressor, and not just a valve . . .).
Old June 16th, 2017, 06:23   #10
thundershorts
If the outside humidity is high, and you are not running it in recirc mpde, the coils in the evaporator will freeze over with ice. if you turn off a/c for a few minutes it will thaw and airflow will be normal. to avoid this just run it in max which is recirc air only
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old June 16th, 2017, 11:33   #11
tadawson
In 40+ years of AC use and work in multiple climates, I have *NEVER* found thst to be true with a properly working system! NEVER!
Old June 16th, 2017, 11:44   #12
Good Ol' Boy
VeeDubTDI's Avatar
Thumbs up
Today, I learned...
Thanks, Tim!
Old June 17th, 2017, 04:27   #13
thundershorts
As I said, turning off the ac for a couple minutes will thaw the ice blocking airflow if the evap coil is iced. Systems are most often designed bleeding hot air from the heater core in to eliminate this. I've seen this many times over the last 60 years and it usually only happens when humidity is very high. You can not recreate this in a shop situation, only in a driving situation. Just set it to max which cuts off most of the moist incoming outside air and it won't happen.
Old June 17th, 2017, 14:57   #14
powerfool
What is the latest hardware for VCDS? Is there any iOS equivalent that I could load with a bluetooth device to monitor?
UPDATE: I see the Hex-Net device and VCDS-Mobile. I am actually surprised by the lack of a price different between the Professional and Enthusiast models of the Hex-Net... it is not very significant from a percentage perspective.
As an update, they said that my refrigerant was fine and they couldn't reproduce the issue... but, when I got it back yesterday, it was blowing really cold air. I don't buy it. The guy that mans the phone and scheduling at the service center for my dealer likes to blow a lot of smoke... I don't think I have had a single conversation with him that didn't include a fair amount of BS on his part. If/when this surfaces again, I will take it to another VW dealership (I have one closer to where I live now, anyhow).
On a side note, I had the fix done and the only thing I really notice is regen happening much more often.
Old June 20th, 2017, 04:49   #15
Rico567
<snip>
The latest hardware that incorporates VCDS is apparently the new HEX-V2 model, which I know nothing about, since I bought VCDS-Mobile before it came out. I bought VCDS-Mobile used, and it provides the full features of VCDS (as long as one has access to a wireless network while using it). I bought it, not because I use many of the more sophisticated features, but because most of the rest of the diagnostic units out there aren't very useful.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Air conditioner condenser failure at 66k miles / 2.5 years frugality VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 July 28th, 2012 07:19
Air Conditioner Service - Air Temperature Measurements neilcaruana VW MKIV-A4 TDIs (VE and PD) 6 April 24th, 2011 01:45
Air conditioner does not work on high air blower setting Wayne Boudreau TDI 101 17 July 29th, 2007 05:27
Air Flow Wire Clogged -- by K&N AIR FILTER??? tsterkel VW MKIV-A4 TDIs (VE and PD) 15 July 1st, 2003 12:59
Removing Air Screen in MAF increases Air Flow SkyPup TDI Power Enhancements 18 June 15th, 2001 18:43
Page generated in 0.17348 seconds with 11 queries
[Output: 132.72 Kb. compressed to 111.54 Kb. by saving 21.18 Kb. (15.96%)]
