Old June 7th, 2017, 15:45   #1
Bob u
Default Tire?
It's time for me to replace the factory Hankook Optimo tires. These HanKook tires were to noise for me.
I'm looking for a quite, smooth riding and great gas mileage tire.
I'm looking at these three:
Michelin Premier A/S
Continental Truecontact
Pirelli Cintureto P7
What all do you recommend?
2013 Passat TDI SE M6
Bob u is offline   Reply With Quote
Old June 7th, 2017, 16:21   #2
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Same as my Passat, it came with crappy Hancook tires. Noisy, noisy YES !!!
These are what I'll be putting on!
http://generaltire.com/tires/passeng...n/altimax-rt43
And this is the reason why ! Read the report and what they rated the second best tire !!! I'll be going up one size to 245 - 45 -18 from factory. By doing this it will actually bring the speedometer in line with the real speed. Also where I live I have a quote for 4 tires installed, balanced and tax for Cdn $ 820.00
http://www.wheels.ca/guides/best-all...ires-for-2015/
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.Average 1 year 30/6/16 to 30/6/17 - 50.71 Mpg - 5.56 L/h
Jetta_Pilot is online now   Reply With Quote
Old June 7th, 2017, 18:58   #3
dbias
Pirelli P7 all the way. Seemed like a different car. Had a little trouble keeping them balanced initially bit chalked it up to getting them installed last thing before they closed on a Saturday afternoon. This exact same tire came on my Audi A4, the Tdi replacement, and are very quiet.
dbias is offline   Reply With Quote
Old June 7th, 2017, 20:33   #4
Bob u
I'm looking at Michelin Premier on Tire Rack, What the difference between 94H and 94V?
Old June 7th, 2017, 22:49   #5
tadawson
Speed rating . . .
tadawson is offline   Reply With Quote
Old June 8th, 2017, 05:54   #6
thundershorts
Even more important is alignment. If your alignment is set optimally, as I did, Contis are good for 80k miles with no rounded edges. I would not ever advise anyone to upsize tire width as it can adversely affect wet performance and stopping.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old June 8th, 2017, 08:25   #7
Jetta_Pilot
In all the years I had my previous 2002 Jetta TDI I had NO ADVERSE PROBLEMS in any weather conditions with a one size update. As I said, it also adjusted the speedometer to actual speed as measured with a GPS instead of reading 5% higher than actual road speed !
As a matter of fact a wider/larger tread will give you a larger surface on the road and in effect give you better road holding ability ! The larger the surface attacking the road, the better the grip on the road !
BTW: The manufacturer will install the minimum required size for the weight and load capacity of a vehicle. They always offer a larger size for additional charges.
Old June 9th, 2017, 05:59   #8
740GLE
We have been extremely happy with Nokian enTyre 2.0s. They were very very competitively priced and shocked how low they were specially in the 18" variety, I think it was around 600 mounted balanced. They are silent, handle great for an eco tire and tread life seems great, only 30K on them and the "water wear" marks say 60%
Nokians are harder to find but there are two great local shops that have offer great prices and great service.
Old June 9th, 2017, 06:01   #9
740GLE
Same here, had one size up on the jetta both summer and snows.
205-60-16 summer and 195-70-15 snows, snows looked great and both had no worse handling performance.
Old June 9th, 2017, 07:16   #10
Bob u
Thanks for your input.
I am trying to decide between these two, Michelin Premiers A/S or Pirelli Cinturato P7 All Season Plus.
Looking for a smoother and quieter ride but maintain my MPG.
What do you all think?
Old June 11th, 2017, 14:36   #11
New Mickey
The user formerly known as mickey
TDI(s): 2015 Passat
I was surprised and disappointed to see Hankooks mounted as OEM. They sound like rock crushers. Just about anything would be a step up.
I like Nokians a lot. But in general I like to look at user reviews on Tire Rack. See what others have to say.
-mickey
New Mickey is offline   Reply With Quote
Old June 11th, 2017, 15:05   #12
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
The Hankooks are terrible. We went with Michelin Primacy MXV4s (now discontinued) and got double the life out of them with significantly less noise. Running Michelin MXM4s now and they seem to be quite nice, as well.
Trusted TDI Mechanics Map || TDIClub Chat
Old June 11th, 2017, 17:22   #13
Rico567
We are at 59K miles on our '13 Passat, 4 years old next month, and still driving (much to my amazement) on the OEM Conti Pro Contacts. They still ride smoothly and quietly, with excellent directional stability, and there's still at least as much rubber above the wear bars as from there to the bottom. Going to need another set of tires here in a few months, definitely before the snow flies. I'd like to save some money on this set, since we're turning the car in on the buyback 12/18, but these Continentals have just been so good......
NB: The Hankooks had such a bad rep four years ago that I told the salesman we would refuse delivery on the car if it was delivered with them.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is online now   Reply With Quote
Old June 11th, 2017, 21:30   #14
jrm
Fuel Economy: 42/52
I'm at 91k on my OEM Conti Pro Contacts, inside of the rear's are smooth but no steel showing yet They still ride perfect
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old June 14th, 2017, 05:38   #15
740GLE
If there's no steel belts showing, you're good for another 10K easy!
Excessive tire wear inside edge one tire only MrBigTruck TDI 101 2 October 23rd, 2010 17:07
JSW Specific Tire Reviews @ the Tire Rack Canyonlands VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 September 10th, 2010 19:58
2010 JSW tire fails! Freeway incident. Second car involved with damage from tire. Rod Bearing VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 12 September 4th, 2010 10:06
limp mode, tire-tire pas.... *DELETED* Silver Star Quebec 10 May 10th, 2005 06:30
Will A Full Size Tire Fit in a (A3) Spare Tire Well? Ric Woodruff VW MKIV-A4 TDIs (VE and PD) 10 September 4th, 1999 01:41
Page generated in 0.17602 seconds with 11 queries
[Output: 126.73 Kb. compressed to 105.31 Kb. by saving 21.43 Kb. (16.91%)]
