Old July 7th, 2014, 19:50   #1
compu_85
Gadget Guy
compu_85's Avatar
Default Pairing remotes to the BCM in the NMS
Has anyone tried to pair keyless remotes to the BCM in one of our cars? I got a used highline control module so I could do factory style foglights on our SE car, however the adaptation channel where you tell it the number of remotes you want to add is always not available. I've made sure all the doors are unlocked, tried with the DS door open, closed, ran a clear command with channel 00... all to no avail.
The car the module came from had Kessy. Does that somehow change the matching procedure?
Thanks!
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old July 8th, 2014, 00:55   #2
vw_norm
Gone, but not forgotten.
From what I've read, this is a dealer task since they have to connect to the mothership and get all the black boxes talking nice with each other with the immo 5 that we have. My adaption map does not show anything for a fob. Only channel 6 for comfort remote control as 'on'. What channel you looking for? I only have 3, 5, 6, 10, 11, 12, 17, 18, 19, 20, 22, 23, 24, 25, 27, 29, 30, 31, 32 and 33 listed, with the rest not available.
vw_norm is offline   Reply With Quote
Old July 8th, 2014, 06:38   #3
compu_85
Gadget Guy
compu_85's Avatar
I didn't do a map, but offhand that list seems correct. The remote matching should be channel 1.
http://www.ross-tech.com/vag-com/car...-matching.html
This isn't immobilizer pairing - just the keyless central locking. I can start the car after switching the BCM.
-J
Present:
Past:
Old July 9th, 2014, 07:57   #4
dzcad90
Rolex & gin
dzcad90's Avatar
Hate to ask the obvious.. but did you ask Ross-Tech?
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Old July 9th, 2014, 09:29   #5
Bobmws
When I had the control module replaced in mine to fix the trunk opening problem, they had to reprogram the keys. I only had one key with me at the time, and noticed the keyhole cover at the door handle was missing when I got home. Turns out the mechanic had it on his bench and replaced it after I brought the 2nd key in to program.
Maybe to key has to be in the door lock for some reason when programming.
Bobmws is offline   Reply With Quote
Old July 11th, 2014, 05:11   #6
compu_85
Gadget Guy
compu_85's Avatar
Posted on the ross-tech forums. No info yet except one person saying it's not possible....
-J
Present:
Past:
Old July 11th, 2014, 09:54   #7
compu_85
Gadget Guy
compu_85's Avatar
So I found the lowline BCM has the adaptation channel:
Interesting that it says 5 remotes have been paired... only have the 2 that came with the car.
The highline BCM does not have channel 01 available:
I hope I don't need to retrofit kessy / change all the keys just to get the cornering lights working
-J
Present:
Past:
Old July 13th, 2014, 13:37   #8
compu_85
Gadget Guy
compu_85's Avatar
I can't recall... perhaps someone here does: Did the SE/Nav/Foglights cars have Kessy?
-J
Present:
Past:
Old July 14th, 2014, 11:03   #9
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
-J
Don't worry about retrofitting KESSY, because that is not going to happen.
Trusted TDI Mechanics Map || TDIClub Chat
Old September 21st, 2015, 00:58   #10
filic
TDI(s): VW Sharan
Hello Guys, have you managed to pair remote controls? I have similar issue. Adaption channel 001 is not available on midline 086M BCM. When checking back the old BCM 084D I can match remote controls without issue.
filic is offline   Reply With Quote
Old September 22nd, 2015, 09:43   #11
AARodriguez Corp.
AARodriguez Corp.'s Avatar
-J
So if you press Read in channel 1 it does nothing or it shows "N/A" or ?
Some MK6 and NMS have alternate programming instructions.
Go to Channel 0, do the reset to factory defaults.
Now to Channel 1, press "test" then "save"
Now press any button on a FOB, this should have it programmed.
Now while you are still in Channel 1, press "test" then "save"
Now press any button on another FOB
Now both FOBs should be programmed.
AARodriguez Corp. is offline   Reply With Quote
Old July 6th, 2017, 18:13   #12
compu_85
Gadget Guy
compu_85's Avatar
I get the message: Error Channel 01 not available.
What is interesting: if I go to measuring block 091 it shows 2 remotes are paired, and in 092 the blocks change when I press the remote buttons, so this BCM has the right hardware.
I verified the coding on the 2 modules is the same. It just blocks the adaptation for some reason
-J
Present:
Past:
BCM Module powerstroker363 VW Passat Family (NMS and B7) TDIs (2012+) 9 September 26th, 2013 06:52
Page generated in 0.19658 seconds with 11 queries
[Output: 122.88 Kb. compressed to 104.95 Kb. by saving 17.93 Kb. (14.59%)]
