Old February 28th, 2016, 09:35   #61
RoadRunnerTR21
2013 Honda Pilot EXL with Navigation in the garage
Sold 2012 Passat SE TDI back to VW on 12/1/2016
RoadRunnerTR21 is offline   Reply With Quote
Old February 28th, 2016, 13:35   #62
jrm
Fuel Economy: 42/52
its the same as o2 sensor cleaning
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old February 29th, 2016, 04:18   #63
1gunther1
Originally Posted by AtlantaRene View Post
Is the NOx sensor problem localized to the earlier model years?
My car is a 2013. Is that an early car?
1gunther1 is offline   Reply With Quote
Old February 29th, 2016, 04:35   #64
AtlantaRene
Possibly, the Passat was redesigned in 2012; however, most of these parts are used on other cars. I was just trying to figure out the problem occurred in certain years... it might indicate that it was fixed by a mid-production change.
-- AtlantaRene
My commute is only 8 miles.
AtlantaRene is offline   Reply With Quote
Old February 29th, 2016, 06:06   #65
1gunther1
I have a 2012 as well with twice as many miles and luckily it has had ZERO issues.
Old March 4th, 2016, 07:17   #66
doug022984
You're lucky. My NOX sensor has failed THREE times now!! First time at ~37,000 miles (conveniently 1000 miles after VW's standard factory warranty), second time at ~61,000 miles, and third time at ~73,500 miles. Luckily they were all covered under my extended warranty, but it makes me worry how costly this nuisance will be once my warranty expires. The last one only lasted a little over 10,000 miles.... I also asked my VW dealership this last time if it was a common issue for these NOX sensors to fail and he said "NO" (while not looking me in the eye), but clearly with the numerous responses to this thread, it's a common issue. Look forward to learning the cleaning method in another year when my warranty expires.
doug022984 is offline   Reply With Quote
Old March 6th, 2016, 09:37   #67
jrm
Fuel Economy: 42/52
Zero issues here too, I wonder if short trips vs highway is causing them to fail? They are located well after all after treatments so they should stay clean no matter what
Old March 6th, 2016, 10:15   #68
AtlantaRene
I am wondering about the cost of the repair. The part is $530 plus taxes, the total cost of the repair is about $1050 so there is about $475 of labor? I don't know the current labor rate of VW dealers but wondered if this was consistent with the amount of diagnostic work, testing, replacement, and then follow on testing required to the task.
@jrm I suspected my short commute may be a factor but then I see doug022984, a high mileage person, who is having the problem.
-- AtlantaRene
Old March 6th, 2016, 12:48   #69
BPofMD
I had the P2201 / NOx Sensor / Bank 1 CEL come on after getting a mechanical car wash driving to Florida from MD. After getting the code read at an Auto Zone I figured (or hoped) the light came on because of the sensor getting wet. The light went out after arriving in Naples, FL the next evening.
I wonder what others would have come up with if they had run the car thru many "drive cycles" before they took it to the dealer?
2012 Passat TDI SE (Awaiting 3/9/17 Buy-Back)
2015 Lincoln MKZ Hybrid
2005 Ford F250
2007 Arctic Fox 5th Wheel
BPofMD is offline   Reply With Quote
Old March 6th, 2016, 13:26   #70
IXLR8
I have a '12 Passat TDI 6M, over 90% of my driving is on the highway, 200 miles at a time. I have been getting NOx sensor errors starting at about 35K miles on the car... still getting them with 83K miles on the car. I haven't bothered to repair it... drive more worry less. Sensor/module is stupid expensive and some bottom heat shields need to be removed to remove wire. I still haven't located the module as wire disappears under heat shield and I haven't found where it comes out.
Jim Peck
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 290K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear.
IXLR8 is offline   Reply With Quote
Old March 6th, 2016, 13:33   #71
IXLR8
List price is $530, but 1stvwparts has it for $380, for the DIY'ers.
Jim Peck
Old March 6th, 2016, 18:50   #72
AtlantaRene
On the night the check engine light came on, I was on a road trip where I encountered 200 miles of rain. At one point, the rain was so heavy that water collected on the roadway and there was a risk of hydroplaning. At times, the interstate slowed down to 40 MPH. After the light came on, I drove the remaining 50 miles to home and full day with the check engine light on before bringing it to VW.
Perhaps water is a factor.
-- AtlantaRene
Old March 7th, 2016, 06:18   #73
BPofMD
I kept going even with the CEL on as the light was NOT flashing. Everyone SHOULD know that if the CEL is NOT flashing there isn't much (if ANY) harm to continue driving. I also did not see a change in MPG so I just quit sweatin' it.
2005 Ford F250
Old March 7th, 2016, 06:35   #74
1gunther1
I wrote to VW America complaining about this known defect and the different treatment by the dealers and to my surprise they have tentatively agreed to repay me. I will keep you posted when and if I get a check.
I recommend everyone who gets one of these to complain to VW about their poor design.
Old March 7th, 2016, 15:15   #75
tc1uscg
tc1uscg's Avatar
TDI(s): SOLD TO VW
Got mine replaced around 27k miles (warranty of course)
No More TDI
tc1uscg is offline   Reply With Quote
New Car, Faulty NOx Sensor 13PassatTDISE VW Passat Family (NMS and B7) TDIs (2012+) 11 March 16th, 2017 11:03
New Car, Faulty NOx Sensor 13PassatTDISE TDI 101 1 February 25th, 2014 03:55
Touareg TDI NOx sensor, any alternatives? mrrhtuner VW Touareg TDIs 3 January 27th, 2014 14:07
Turbo Sensor bad? Rudy 'D' TDI 101 0 June 19th, 2011 17:57
Which is the bad sensor? chewbacca TDI 101 2 May 29th, 2007 06:00
Page generated in 0.18279 seconds with 11 queries
[Output: 127.99 Kb. compressed to 107.11 Kb. by saving 20.88 Kb. (16.32%)]
