Old March 13th, 2014, 11:41   #31
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Thumbs up
Originally Posted by Nuttendiesel View Post
put in the Osrams from Candlepower at $76 for 4 and thought it was a pretty good upgrade for the money, much better light but still lacking a little, I was coming from a 2010 accord that I retrofitted with s2k projectors but that cost me over $700 and the output is unreal, makes my other car with stock xenons really seem dim by comparison but after turning off the bulb saving feature via vcds i now have pretty respectable output and am happy with it plus my sister-in-law just bought a 14', I told her i'll do the upgrade for her, found this
http://www.ebay.com/itm/10X-OSRAM-Sy...-/171264843521
on ebay and figured what the heck, they appear to be the real deal and i cannot tell the difference when comparing them side to side, now i can change out low beams every year for $10!
That's a pretty nice price if they're the real deal! Probably parts store shrinkage, though... I can't think of any other reason to sell that cheap.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is online now   Reply With Quote
Old March 13th, 2014, 11:50   #32
DieselRacer
banned
Fuel Economy: 30.6 combined
They are always that price on there from what I remember, how long do these bulbs last compared to OEM bulbs...
DieselRacer is offline   Reply With Quote
Old March 13th, 2014, 15:14   #33
dcullen
Default rated Life
Standard 55w H7 are rate 450 hours, Osram 65w Rallyes are rated 400 hours
50% greater lumen output.
Sylvania Silverstars (US) rated at 200 hours
dcullen is offline   Reply With Quote
Old March 13th, 2014, 15:15   #34
Good Ol' Boy
VeeDubTDI's Avatar
Silverstar's rating of 200 hours is ridiculous. I'd be changing lamps frequently at that life span...
Old March 13th, 2014, 16:59   #35
LokiWolf
LokiWolf's Avatar
They last FAR longer than 200 hours!
2013 Passat TDI SEL (Daily Driver)
LokiWolf is online now   Reply With Quote
Old March 13th, 2014, 19:00   #36
tdiatlast
^^^this...in my experience...
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old March 13th, 2014, 19:58   #37
macoombi
Originally Posted by vw_norm View Post
The lights will run at 65 watts regardless of the voltage supplied. They will just pull more current (more amps).
This is incorrect. A simple light bulb acts like a simple resistor. V=IR applies. The higher the voltage, the higher the current flow for a given resistance. And since power is voltage time current, when the voltage and current go up, so does the power. More power = more light output.
Ever notice the headlights getting brighter when you increase the rpms from idle? That's proof.
macoombi is offline   Reply With Quote
Old March 13th, 2014, 20:05   #38
macoombi
Originally Posted by tadawson View Post
False! Incandescent lamps are a variable resistive load, and also have a reverse temp to resistance relationship (resistance goes *down* as it heats) and will draw more power at higher voltage, being limited by failure. Wattage ratings are at the design voltage, and only that voltage. Think about what you said - if it were true, you could get the same output with 6 volts as 12, and we all know that to be false as well.
So yes, while P=IV, P is also V^2/R or I^2*R (using ohms law, V=IR to solve for I or V).
Note P=V^2/R . . . power not only goes up, but goes up at the square of the voltage!
- Tim
You're also partially incorrect. Tungsten bulbs don't have an inverse temperature coefficient. The resistance goes up with heat. Perhaps you're thinking of the early carbon filament bulbs from the late 1800s.
But the rest of what you posted is good.
Old March 14th, 2014, 07:07   #39
Hypermile
But you can retrofit 55W H11s by dremeling down the big tab on the base about 1/16" on each side for a noticeable improvement in output.
Thanks, check my sig.
2013 Candy White Passat TDI DSG, Comfortline, Sports Package // 35% Ceramic Tint // LED Interior Lights // Euro Switch // LED Front & Rear Turn Signals/Markers // LED Front Corners Lights // LED Rear Inner Tail Lights // LED Puddle Lights // OEM LED Plate Lights // Nokya 2500K H11 55W Fogs // FX-R 3.0 Bi-X Projector Retro // 6000K 55W HID // IROAD IONE-900HD // LED Strip Trunk Light // Auto-Polar FIS+ Adv.
Hypermile is offline   Reply With Quote
Old July 7th, 2014, 15:10   #40
JM Popaleetus
JM Popaleetus's Avatar
Well, one of the low beam bulbs went out on the Passat today, so I decided that now is a good time as ever to buy the Rallye 65W bulbs (and get the recall done).
Bumping this thread because I came across an interesting link: http://www.danielsternlighting.com/p.../products.html
The Flösser and Osram bulbs are electrically, optically, functionally, and qualitatively identical, but they are labelled differently. They are both built in Germany to exactly the same specification: an H9 burner on an H7 base, 65w at 12.0v, 2100 lumens at 13.2v. Flösser's box says "80w" while Osram's says "65w". This is not an actual power difference, it is a test voltage difference. Flösser power-rates their bulb at 13.5v rather than 12.0v. For any/all filament bulbs, the wattage rises exponentially to the power 1.6 with voltage increase. So a bulb rated 65w at 12.0v will be rated 78.5w (printed as 80w) at 13.5v. It's not two different bulbs, just two different test protocols. On the test bench, the Osram "65w" bulbs and the Flösser "80w" bulbs all test out at between 63.8 and 65.4 watts at a constant 13.2 volts.
It also appears that the maximum life expectancy of ~500 hours is measured at 13.2V as well.
Luckily for me, I also finally ordered a VCDS, so 13.2V is now what I plan to set the voltage at.
2013 VW Passat TDI SEL Premium (Candy White/Cornsilk, Lip Spoiler, 17" Salamancas)
2010 VW Jetta TDI Sedan (DSG, White Gold/Cornsilk, Sunroof) RIP
2007 GMC Sierra 2500HD Duramax (Classic, Extended Cab, Summit White/Ebony)
JM Popaleetus is offline   Reply With Quote
Old October 27th, 2014, 13:13   #41
Lincoln
Just reread through this whole thread and can't find anyone who installed 65W bulbs in place of 55W bulbs WITHOUT adjusting voltage who noticed any significant difference... Is that correct? I rented a Mustang yesterday and its lights were so much brighter than my stock lights that it made me look this back up. Now that we're back to morning-and-evening-commuting-in-the-dark in Seattle, it's a pressing issue. However, I don't have VCDS, so don't want to shell out for new bulbs if it won't make any difference at all...
Lincoln is offline   Reply With Quote
Old October 28th, 2014, 04:48   #42
TheGrove
I would guess, and this is true for me, that most of us that installed the 65W bulbs want the lights to be as bright as possible so we upped the voltage to make sure they are opperating at full power. You might want to check out the VAG-COM locator in this thread there appear to be several in the Seattle area that could help you.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old October 28th, 2014, 17:15   #43
LokiWolf
LokiWolf's Avatar
Yep, even the stock bulbs improved with just the voltage...
Old October 28th, 2014, 20:56   #44
tdiatlast
...and there should be sticky telling everyone to adjust their headlights before they jump to the conclusion that they're completely worthless...
Old October 29th, 2014, 14:55   #45
Good Ol' Boy
VeeDubTDI's Avatar
It should be added to the FAQ thread. We don't need more stickies.
Voltage regulator; voltage needed and bosch quality? guillaumeber VW MKIV-A4 TDIs (VE and PD) 3 September 7th, 2013 12:33
Can the headlight wiring harness handle 65W bulbs? Doug3 VW MKVI-A6 Jetta Sedan (~ 2011+) 11 December 12th, 2012 20:35
Installed osram 65w bulbs lonniebear VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 April 24th, 2011 07:51
Osram H7 Rallye 65w Bulbs patter98 VW MKV-A5 Golf/Jettas 6 January 26th, 2010 17:54
voltage, no voltage, wait voltage! uhh no voltage wgargan TDI 101 1 December 10th, 2009 20:42
Page generated in 0.16661 seconds with 11 queries
[Output: 134.78 Kb. compressed to 113.47 Kb. by saving 21.31 Kb. (15.81%)]
