Old December 10th, 2013, 15:47   #1
ss2nv
Default OSRAM 65w Rallye AND Upping Voltage with VCDS?
Hello. We just purchased a 2014 Passat SEL TDI and I am unhappy with the factory headlight output. I have read around and have decided to install the OSRAM 65 watt Rallyes. I have seen where others have done this and been happy, but what about also upping the voltage with VCDS? The OSRAM bulbs say that they are rated for 12 volts on the box. I just purchased the Micro-CAN cable from Ross-Tech and was wondering how high I could go with the voltage, or even disable the bulb-saver feature alltogether? Any thoughts?
Thanks.
Seth
ss2nv is offline   Reply With Quote
Old December 10th, 2013, 15:52   #2
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Disabling the life extender will increase the voltage to whatever the alternator is putting out.
Trusted TDI Mechanics Map || TDIClub Chat
Old December 10th, 2013, 15:59   #3
ss2nv
Right, but is it okay to do with these bulbs, being that they are 65 watt vs the factory 55 watt? I don't want to have to worry about the wiring, bulb-housings, or sockets burning up/melting.
Thanks.
Seth
Old December 10th, 2013, 18:25   #4
JM Popaleetus
JM Popaleetus's Avatar
I thought you could actually dial in a voltage/wattage (one or the other)?
Gonna have to do some reading again.
2013 VW Passat TDI SEL Premium (Candy White/Cornsilk, Lip Spoiler, 17" Salamancas)
2010 VW Jetta TDI Sedan (DSG, White Gold/Cornsilk, Sunroof) RIP
2007 GMC Sierra 2500HD Duramax (Classic, Extended Cab, Summit White/Ebony)
JM Popaleetus is offline   Reply With Quote
Old December 10th, 2013, 18:47   #5
ss2nv
As far as I know, it is just a voltage adjustment(or turn off the bulb-saver mode completely). I just got back inside from swapping out my factory 55 watt H7 Hi/Lows for the OSRAM Rallye 65 watt bulbs. Afterwards, I used VCDS to up the voltage on the headlights and taillights to 13.5 volts. I also set the Comfort Turn Signal Cycles from 3 to 4 and disabled the Hill-Hold feature, as I have a DSG car. I am still looking at how to have the fog lights on with the DRLs and highs, though.
Old December 10th, 2013, 19:18   #6
Good Ol' Boy
VeeDubTDI's Avatar
You can indeed select a voltage. Disabling it completely runs them wide open at whatever the electrical system is at.
Old December 10th, 2013, 20:38   #7
Jbratstdi
Fuel Economy: 43.5 Avg
Cent elec. 09 look for fog lights active with DRL
Jbratstdi is offline   Reply With Quote
Old December 10th, 2013, 21:10   #8
JM Popaleetus
Anyone know what the current draw is on our headlights?
Essentially, is 13.5V what you want to run in order to have the Rallyes going at their full 65W?
Old December 11th, 2013, 00:45   #9
vw_norm
Gone, but not forgotten.
Thanks.
Seth
Wattage is current times voltage. W=I*V. With higher voltage settings, such as with bulb life extension disabled, provides full electrical system voltage to your lamps. It can handle it since there is actually less amps flowing to the (stock) bulb.
With 12.6 VDC and 55 Watt lamps, that equates to 2.5 Amps.
With 14.0 VDC and 55 Watt lamps, that equates to 2.3 Amps
With 14.0 VDC and 65 Watt lamps, that equates to 2.7 Amps
0.2 amp increase is negligible.
The lights will run at 65 watts regardless of the voltage supplied. They will just pull more current (more amps) attempting to attain the rated output.
The rest of the car is seeing 13.9 - 14.1 VDC from the voltage regulator (per my scan-gage) and has suffered no ill effects in the over one year that the tail and head light 'life extension' has been disabled in my car. And there have been more than a few electrical tweaks along the way as well.
I don't think that the cost of a lightbulb being "life-extended" by a lower voltage supplied outweighs the benefits achieved by operating them at their full rated voltage, and thus their full rated output. They are not that difficult to change.
vw_norm is offline   Reply With Quote
Old December 11th, 2013, 01:42   #10
TheGrove
Thanks.
Seth
Yes, I have my bulb saver turned off and the voltage set to max and run the OSRAM's in both high and low beams.
2012 Passat SEL Premium TDi Opera Red
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old December 11th, 2013, 08:22   #11
JM Popaleetus
Sounds good! Thank you!
My wallet is going to cry ordering 8 bulbs, but it'll be worth it.
Old December 11th, 2013, 10:34   #12
tadawson
False! Incandescent lamps are a variable resistive load, and also have a reverse temp to resistance relationship (resistance goes *down* as it heats) and will draw more power at higher voltage, being limited by failure. Wattage ratings are at the design voltage, and only that voltage. Think about what you said - if it were true, you could get the same output with 6 volts as 12, and we all know that to be false as well.
So yes, while P=IV, P is also V^2/R or I^2*R (using ohms law, V=IR to solve for I or V).
Note P=V^2/R . . . power not only goes up, but goes up at the square of the voltage!
- Tim
tadawson is offline   Reply With Quote
Old December 11th, 2013, 11:05   #13
vw_norm
OK. I stand corrected. I was trying to keep it simple. 6v is an extreme example.
Old December 11th, 2013, 12:48   #14
50pascals
I think the issue here may be that "12 volts" does not necessarily mean 12.0 volts. Since the inception on 12 volt electronics, a fully charged "12 volt" battery will read 14.1 volts.
In fact a battery that reads 12.0 volts is half dead.
So if Osram did not design this bulb to be tolerant of 14.1 volts (or higher) they are incredibly stupid.
I am interested to know what the actual voltage is when measured at the bulbs. I personally have installed relays and heavier wiring on cars to ensure maximum power available that would otherwise have been hampered by restrictive wiring.
50pascals is offline   Reply With Quote
Old December 16th, 2013, 17:43   #15
ss2nv
I appreciate all of the helpful replies. The 65w Rallyes have been going fine running at 13.5 volts. I went out tonight and upped it to the maximum 13.6 volts (while still having the bulb-saving feature on) in VCDS. I also turned on the instrument needle sweep (celebration) on start-up, DRL On/Off via MFI, and Fogs as DRLs.
My car is a 2014, so I was a little apprehensive when applying the changes, as most, if not all of the info that i have read concerning VCDS and NMS cars is about using it on 2012-2013 models. Anyway, the instrument sweep worked and the DRL function showed up on the MFI. It was too dark to test the fogs as DRLs.
I would still like to find out how to open/close the sunroof via the fob, though. I am sure that I have read over it in some other thread, but missed it.
On a different note, should I be worried about running this car through a car wash? I have read stories about the sunroof drains not being securely connected and leaking into the headliner. A high-pressure touch-less carwash would spray some serious water onto the roof...
Voltage regulator; voltage needed and bosch quality? guillaumeber VW MKIV-A4 TDIs (VE and PD) 3 September 7th, 2013 13:33
Can the headlight wiring harness handle 65W bulbs? Doug3 VW MKVI-A6 Jetta Sedan (~ 2011+) 11 December 12th, 2012 21:35
Installed osram 65w bulbs lonniebear VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 April 24th, 2011 08:51
Osram H7 Rallye 65w Bulbs patter98 VW MKV-A5 Golf/Jettas 6 January 26th, 2010 18:54
voltage, no voltage, wait voltage! uhh no voltage wgargan TDI 101 1 December 10th, 2009 21:42
Page generated in 0.17579 seconds with 11 queries
[Output: 136.30 Kb. compressed to 114.70 Kb. by saving 21.59 Kb. (15.84%)]
