Old March 21st, 2014, 14:20   #61
IXLR8
How do you reset the "service reminder" when you have completed the service? I just completed doing my 40K service, I have a VCDS, I just haven't figured out how to reset the service reminder.
Jim Peck
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 290K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear.
IXLR8 is offline   Reply With Quote
Old March 24th, 2014, 18:09   #62
Sandhopper
Fuel Economy: 38
Just had my 40k with the DSG serviced for $593.02. Called around to several VW dealers and the closest to home was the cheapest. BTW, when they quoted the job it was $618... They came in under their quote. I was amazed!
Good to go for another year.
2013 Passat SEL TDI - Tungsten Silver Metalic with Titan Black Interior
Sandhopper is offline   Reply With Quote
Old April 1st, 2014, 09:12   #63
psd1
Fuel Economy: See Fuelly link
Has anyone been able to cross the fuel filters for the NMS? NAPA had their annual half price sale and were unable to source a filter. $40+ is a lot for a filter!
psd1 is offline   Reply With Quote
Old April 2nd, 2014, 09:31   #64
Rico567
Originally Posted by psd1 View Post
<snip>$40+ is a lot for a filter!
One source / proprietary = $40. When Wix & everybody else starts making it, $10.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is online now   Reply With Quote
Old April 2nd, 2014, 12:45   #65
psd1
Wonder when/if after markets can start copying?
Old May 25th, 2014, 07:30   #66
d2305
With the hpfp failures, I would only use Mann. Aftermarket oil filters are available.
d2305 is offline   Reply With Quote
Old June 14th, 2014, 06:26   #67
JARED_LA
Can anyone post the thread showing all of the required tools to perform oil and fuel filter changes, including belly pan, req'd torque, etc.? Also, for the bottom drainers, are you guys lifting up the front only using ramps?
Jared
JARED_LA is offline   Reply With Quote
Old June 14th, 2014, 06:34   #68
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
Originally Posted by VeeDubTDI View Post
There is special sunroof grease/lube available. Not sure who sells it, but I'm sure a quick Internet search will return some results.
ID parts sells it.
2015 Golf SE TDI with DSG, 50k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old June 17th, 2014, 15:28   #69
skinnyb
TDI(s): 2013 JSW TDI
Fuel Economy: Slightly north of 40 MPG
Jared
Not sure of the thread but you will need a 25 and 30 torx for belly pan, 19mm wrench or socket for drain plug. The filter is a 32mm socket. I believe the fuel filter is 25 torx as well.
If you remove the filter housing you will need a 10mm socket there I believe. I do drain mine from the bottom on ramps. I have a fumoto valve with a nipple and just put on a short length of hose and drain right back into an empty 5 liter jug that I emptied the last change.
Sent from my SAMSUNG-SGH-I467 using Tapatalk
2015 Passat 1.8T Limited Edition
2013 JSW TDI DSG Malone 2.0 Eco, Tint, Wheels, Etc...
skinnyb is offline   Reply With Quote
Old July 6th, 2014, 07:01   #70
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Here are some pics from our 60K service...
Nice and clean inside
Fuel filter doing it's job
Air filter doing it's job
Primed the fuel system with the VCDS output test for the fuel system electronics (didn't pre-fill the filter housing). After about 30 seconds all of the air was purged out and it started right up.
Trusted TDI Mechanics Map || TDIClub Chat
Old July 6th, 2014, 09:57   #71
Rico567
VeeDubTDI wrote: "-Air filter doing it's job-" (+pix)
If you changed that filter at a 20K interval, where do you live? I change the cabin filter in our SAAB 9-5 wagon at the recommended 30K interval, and from the appearance of the filter, it's an exercise in futility. They look as clean coming out as they did going in. I've found a few small leaves and a few windborne seeds (maple, etc.) in there, but that's about it.
- Adam Savage
Old July 6th, 2014, 09:59   #72
compu_85
Gadget Guy
compu_85's Avatar
The filter was changed at 60k for the first time.
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old July 6th, 2014, 10:21   #73
Good Ol' Boy
VeeDubTDI's Avatar
... at the recommended interval.
Old July 6th, 2014, 10:30   #74
Rico567
Woops! I didn't think to check the maintenance schedule. When someone earlier in the thread said it was part of the 20K service, I just assumed that was the interval.....
- Adam Savage
Old July 11th, 2014, 11:45   #75
APT
I'm nearing my 40k and have a quote from a local TDI mechanic for labor. Does anyone recommend any of the customizable upgrades from the IDparts kit?
2012 Passat TDI SEL Night Blue/Cornsilk
2017 Subaru Outback 3.6R Limited Lapis Blue
2011 Suburban 2500 family towing beast
APT is offline   Reply With Quote
Has anyone use Wheaton Service center in MD for a 40K Service with DSG change? j1mbo Eastern USA 6 September 11th, 2014 04:36
First DSG service, 40k service done! Jav9882 VW Passat Family (NMS and B7) TDIs (2012+) 8 April 27th, 2013 05:03
40k service checklist pkhoury VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 July 23rd, 2012 11:12
20,000 mile service - checklist torifile TDI 101 18 October 18th, 2006 23:20
40K Service Checklist BoraTdi VW MKIV-A4 TDIs (VE and PD) 7 December 9th, 2000 00:47
Page generated in 0.16435 seconds with 11 queries
[Output: 135.29 Kb. compressed to 113.88 Kb. by saving 21.40 Kb. (15.82%)]
