Old August 19th, 2012, 15:30   #46
compu_85
Gadget Guy
compu_85's Avatar
Originally Posted by sanjaun2 View Post
Thanks for the info on this Jason, Sounded so cool I ran down to autozone and bought one. I went to X-gauge and installed the codes you have above and named them. I then pulled them up on the screen and there is no info displayed next to them. The others like water temp and fuel burn work fine. Any ideas?
You only need to do one or the other depending if you want *F or *C. Silly question... but are you sure you have all the numbers in correctly
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old August 19th, 2012, 17:44   #47
sanjaun2
oooops, I added some zero's to the wrong block. went in and edited it and all works great now. Thanks for the great mod idea and the help. Over 5K trouble free miles and smiles so far. Taking a 4K road trip next week,
199.5 Jetta tdi (sold)
04 Galactic blue jetta tdi
2012 Passat SE Tdi
sanjaun2 is offline   Reply With Quote
Old August 20th, 2012, 05:43   #48
ChadS99SVT
Originally Posted by GeekDrew View Post
Get in the car.
Start the engine.
Plug in the ScanGaugeII. It will start up a few seconds later.
It is still just stuck in the connecting.... and then shuts off.
do you think this has to do with mine being a 2013? is something not programmed to recognize it?
Anyone in here have it working on a 2013 yet? I see in the manual there is a way to "force" the codes to recognize different makes. VW is not mentioned in the manual?
At a loss right now
ChadS99SVT is offline   Reply With Quote
Old August 20th, 2012, 05:46   #49
bigred 7.3l
Mine is a 2013 and no problems. Make sure it is un-plugged and then start the car. Plug it back in. If that does not work call their Customer Service.
bigred 7.3l is offline   Reply With Quote
Old August 20th, 2012, 08:09   #50
ChadS99SVT
bummer ok. Yeah I did that. I got in started the car. Plugged the scanner into the obd2 port and it just sits there and does nothing and eventually just shuts off.
hopefully calling the customer service is not to much of a hassle.
Old August 20th, 2012, 08:15   #51
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Try plugging it in before starting the engine. ScanGauge should work just fine on the 2013.
Do you have another vehicle (1996+) that you can try hooking it up in? There could be a problem with your ScanGauge.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is online now   Reply With Quote
Old August 23rd, 2012, 07:55   #52
ChadS99SVT
Ok probably a dumb question but there is only one place you could plug the scanner in right? I assume the purple port on the left side of the driverside compartment is the obd2 port :whoknows:
I am still trying to get this thing to work, I have been talking with the techs at scan gauge. I have tried to force the codes. etc. they want me to try it in another vehicle so that is on the agenda.
Does anyone know what Code their scan gauges are using?? CANXX?
Old August 23rd, 2012, 08:25   #53
mysql
mysql's Avatar
TDI(s): Jetta wagon
I still use my scangauge2 on my steering column, but if anyone has an android device, you can buy the Torque app and it has a ton of gauges available. In addition to the app, you will need to buy a Bluetooth odb2 connector for it to work. The BT adapter I linked to is the one I purchased, and it has worked well for the last 4 months.
I don't have a recent screenshot, but here's an early one from when I was messing with it. Just to give you an idea what it looks like. There's about 80 sensors it can read from, and a bunch of different style gauges. You're not stuck with just digital. And it has a bunch of skins and themes.
mysql is offline   Reply With Quote
Old August 23rd, 2012, 11:35   #54
Good Ol' Boy
VeeDubTDI's Avatar
Can you explain the conditions at which you captured 1300 EGT and 11 psi?
Old August 23rd, 2012, 11:35   #55
mysql
mysql's Avatar
TDI(s): Jetta wagon
2010 JSW TDI MT. At 90 mph, it would be in 6th gear.
Old August 23rd, 2012, 12:09   #56
APT
Any thoughts on the Ultra Guage Vs. Scanguage II?
2012 Passat TDI SEL Night Blue/Cornsilk
2017 Subaru Outback 3.6R Limited Lapis Blue
2011 Suburban 2500 family towing beast
APT is offline   Reply With Quote
Old August 23rd, 2012, 12:15   #57
Good Ol' Boy
VeeDubTDI's Avatar
Ultra Gauge is less expensive and has a prettier interface but I believe it doesn't calculate fuel economy as well as the ScanGauge. That said, the built-in MFI calculates fuel economy better than either of the aftermarket options.
I do not know if Ultra Gauge has more/less/same functionality compared to ScanGauge.
Old August 23rd, 2012, 12:37   #58
APT
I personally don't care about the trip/fuel measurements. Only gauges, like EGT, boost, load. Seem like it should work for this limited capability for half the cost.
Old August 23rd, 2012, 13:01   #59
JSWTDI09
JSWTDI09's Avatar
I'm still trying to get an answer to a question I asked a while ago. Can any of these aftermarket gauges (ScanGauge, Torque, Ultragauge) actually read VW measuring blocks, as opposed to just generic OBDII PIDs. I really want to know if any of these gauges can read all 4 EGT sensors in CR diesels. I would really like a display that shows the after DPF EGT sensor so that I can monitor DPF regenerations. I would love to be able to display the pre turbo EGT and the post DPF EGT. I know that the sensors are there, but the only way I know of to read them reliably is VCDS.
I get the impression that these gauges work only by reading generic OBDII PIDs. If this is the case, my MFD and my Kufatec E-MFA tell me almost everything these aftermarket gauges can tell me. I don't want to spend money only to be disappointed. TIA
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old August 23rd, 2012, 13:10   #60
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
Have Fun!
Don
I just bought my ScanGauge, so I'm not as up to speed as some others. But, if you take a look at this link, it says that you can monitor four different catalyst temps: http://www.scangauge.com/support/xga...ansf-vehicles/
And a Mk7 GTI that's faster, but more thirsty.
Blue_Hen_TDI is offline   Reply With Quote
Scangauge Boost Gauge and General XGauge Coding info seftonm OBD Scanners 131 May 5th, 2015 10:56
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 20:35
Scan gauge II OntarioVW_TDI VW MKIV-A4 TDIs (VE and PD) 2 March 26th, 2012 18:20
scan gauge II Help OmegaRenegade Ontario 18 December 20th, 2007 07:27
Scan Gauge II BioThomas VW MKV-A5 Golf/Jettas 53 March 13th, 2007 20:43
Page generated in 0.17044 seconds with 11 queries
[Output: 136.16 Kb. compressed to 114.58 Kb. by saving 21.57 Kb. (15.84%)]
