Old May 5th, 2017, 11:02   #526
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
With all the knowledge here about the Scangauge II can anyone here tell me how I can completely reset the SC II to factory? I have a continuing false reading as to how much fuel is required at the next fill up. It had been out by as much as 1000 gallons.
I have had it disconnected from the OBD II port for as long as 4 weeks and the error still comes back.
Also my way of mounting it is very simple. I had a piece of metal bent twice sort of a squared off "U" shape. Part of it slides in between the left air outlet and the dash and the flat part on top is where the SC II is mounted with "Gorilla Tape".
I have a picture how it was on my Jetta and its the same on the Passat. Hope the picture will attach. It does not but the link will take you.
http://pics.tdiclub.com/showphoto.ph...f0004r&cat=all
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Old May 7th, 2017, 07:11   #527
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
There is a setting to restore it to factory defaults, but I don't know where it is in the menu.
For what it's worth, I've found that the fuel economy portions of the ScanGauge are never very reliable and can vary significantly depending on driving style, even when it is properly calibrated with numerous fill-ups.
Trusted TDI Mechanics Map || TDIClub Chat
Old May 11th, 2017, 13:35   #528
Shawn67
Originally Posted by Locoelectrician View Post
My 13 diesel Passat had excellent engine braking, as does my diesel truck. This new car has none.
How is the MPG of the new car vs old.
New engine has more electrically driven (not engine driven) accessories vs the old. That is the difference in engine braking. Less parasitic losses to the accessories which translates to less engine braking.
Shawn
Shawn67 is offline   Reply With Quote
Old May 11th, 2017, 13:36   #529
Shawn67
Is the individual sensor refresh rate determined by the ECU? I ask because I have my scangauge set to "fast", and while egt and DPF update nearly instantly, the pre cat sensor is very slow, and updates in roughly 5 second intervals. If I'm not explaining well enough, egt and DPF will update about once every second or half second and the numbers climb or drop quite smoothly, while pre cat sits at a number for about 5 seconds and then jumps to the next. So instead of 520, 525, 528, bla bla bla, it will be more like 520,............. 580.
Not a huge deal, but wondered if one of the programmed digits sets sensor refresh rate. My guess is no, based on how close the numerology is for egt vs pre cat but thought it was worth asking.
Yup, I see the same thing. It is likely just the sampling rate of the sensor/computer itself.
Shawn
Old May 11th, 2017, 14:06   #530
Locoelectrician
Shawn
That may be part of it but I believe there is more to it than that and I suspect (after talking to Malone) that most of the difference is in the adjustable vanes of the turbo. They claim they can give the engine braking back with a tune.
Locoelectrician is offline   Reply With Quote
Old May 12th, 2017, 08:21   #531
Good Ol' Boy
VeeDubTDI's Avatar
A tune can certainly add significantly more engine braking, if desired.
Scangauge Boost Gauge and General XGauge Coding info seftonm OBD Scanners 131 May 5th, 2015 10:56
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 20:35
Scan gauge II OntarioVW_TDI VW MKIV-A4 TDIs (VE and PD) 2 March 26th, 2012 18:20
scan gauge II Help OmegaRenegade Ontario 18 December 20th, 2007 07:27
Scan Gauge II BioThomas VW MKV-A5 Golf/Jettas 53 March 13th, 2007 20:43
Page generated in 0.15851 seconds with 11 queries
[Output: 84.00 Kb. compressed to 74.36 Kb. by saving 9.63 Kb. (11.47%)]
