Old August 18th, 2012, 13:08   #31
bigred 7.3l
here are some more pics
bigred 7.3l is offline   Reply With Quote
Old August 18th, 2012, 13:17   #32
mrctdi
I like that set up. Just need to find that bracket
mrctdi is offline   Reply With Quote
Old August 18th, 2012, 19:11   #33
ChadS99SVT
My scan gauge arrived today but it's not loading properly. need to sit down and figure it out. been to busy this weekend so far.
ChadS99SVT is offline   Reply With Quote
Old August 18th, 2012, 20:54   #34
bigred 7.3l
make sure the car is running with before you plug it in.
Old August 19th, 2012, 06:26   #35
ChadS99SVT
ah ok. I had it plugged in before starting it. strange quirk if that's the case.
Old August 19th, 2012, 09:09   #36
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
It won't connect unless the computer is powered up.
Trusted TDI Mechanics Map || TDIClub Chat
Old August 19th, 2012, 10:58   #37
ChadS99SVT
hmmm is there a trick to getting that to power up?
I need someone to hold my hand through this setup lol. total amateur obviosuly.
Old August 19th, 2012, 13:56   #38
GeekDrew
GeekDrew's Avatar
TDI(s): None
Get in the car.
Start the engine.
Plug in the ScanGaugeII. It will start up a few seconds later.
GeekDrew is offline   Reply With Quote
Old August 19th, 2012, 14:01   #39
Cogen Man
Cogen Man's Avatar
Fuel Economy: Better than the Toyota FJCruiser
Or just turn key to ON position. Then plug in to OBDII. Mine I didn't need to have the engine running. The manual is your friend.
On set up. Diesel A for fuel type.
Cogen Man is offline   Reply With Quote
Old August 19th, 2012, 14:06   #40
compu_85
Gadget Guy
compu_85's Avatar
VWs don't have an accessory key position
The ScanGauge shuts off it if sees the engine isn't running. Start the car.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old August 19th, 2012, 14:16   #41
Cogen Man
Cogen Man's Avatar
-J
I must have a weird SG then. When I installed mine I just turned the key till all the dash lights powered up, the so called on position then plugged in the SG pushed the mode key and it went threw the connecting thing. Connected in about 20 seconds. Then did the set up.
Old August 19th, 2012, 14:18   #42
Good Ol' Boy
VeeDubTDI's Avatar
It will work with KOEO (key on engine off), but it will go to sleep if you stop pressing buttons. It remains awake when it senses an RPM signal. Either way will work, just keep in mind that the ScanGauge may go to sleep if the engine isn't running and you don't press any buttons for a few seconds (20?).
Old August 19th, 2012, 14:22   #43
Cogen Man
Cogen Man's Avatar
Thanks Mate. Thought I was losing it there. I must have been a really fast button pusher when I installed it a year or so ago.
Old August 19th, 2012, 14:59   #44
sanjaun2
We've gotten a couple questions about how we put EGT on our ScanGauge II, so I'll make a quick post.
I got this information from here: http://www.scangauge.com/support/xga...ansf-vehicles/
If you scroll down in the list you'll find the section labeled "Catalyst Temp Sensors"
Instead of CTF or CTC, use EGT for the label on the units you prefer.
For information on how to program an X-Gauge, read page 38 on the Owner's Manual here:
http://www.scangauge.com/wp-content/...nload.php?id=1
Thanks,
-Jason
Thanks for the info on this Jason, Sounded so cool I ran down to autozone and bought one. I went to X-gauge and installed the codes you have above and named them. I then pulled them up on the screen and there is no info displayed next to them. The others like water temp and fuel burn work fine. Any ideas?
199.5 Jetta tdi (sold)
04 Galactic blue jetta tdi
2012 Passat SE Tdi
sanjaun2 is offline   Reply With Quote
Old August 19th, 2012, 15:05   #45
TDiSkater
Fuel Economy: 35 Winter/41 Summer
Did you add it to an open Xguage slot? I put it in slot one and it didn't take. Toggled over and put it in 3 and worked like a charm. I didn't have the book open and just assumed the first slot was reserved.
VW-OEM European Steel Skidplate | 35% LLumar Tint all around | Pano Sunroof | ScanGauge II | WeatherTech Weatherflectors and Digital Fit Floorliners l Faux TDI Mirror Etching l RGM Bumper Guard | Conti PureContact | Non-OEM Aspherical Mirrors - $3 Blind Spot Mirror | 70,000 miles |
TDiSkater is offline   Reply With Quote
Scangauge Boost Gauge and General XGauge Coding info seftonm OBD Scanners 131 May 5th, 2015 10:56
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 20:35
Scan gauge II OntarioVW_TDI VW MKIV-A4 TDIs (VE and PD) 2 March 26th, 2012 18:20
scan gauge II Help OmegaRenegade Ontario 18 December 20th, 2007 07:27
Scan Gauge II BioThomas VW MKV-A5 Golf/Jettas 53 March 13th, 2007 20:43
Page generated in 0.17164 seconds with 11 queries
[Output: 135.35 Kb. compressed to 113.76 Kb. by saving 21.58 Kb. (15.95%)]
