Old December 14th, 2011, 17:06   #31
darrelld
darrelld's Avatar
Fuel Economy: Fuelly
Originally Posted by TomB View Post
Got the data to prove this?
Has anyone heard that on the DSG they set it to "coast" when you let up off the fuel instead of applying the compression breaking like the standard automatics on the 05 Passats?
Is this true if you are in Sports mode or downshifting it with the tiptronic?
The Passat does freewheel
darrelld is offline   Reply With Quote
Old December 14th, 2011, 17:07   #32
Ski in NC
Fuel Economy: 48-52 typical
DSG has a hydraulic pump running all the time to shift the gears and swap clutches. So there is a parasitic loss that will eat a little more fuel.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old December 15th, 2011, 10:58   #33
MyAvocation
MyAvocation's Avatar
So if I'm reading Darrell's post correctly, the freewheel feature still cuts off fuel delivery -- like older DSGs -- but without engine braking?
MyAvocation is offline   Reply With Quote
Old December 15th, 2011, 13:33   #34
TheGrove
Yes, I have a hill/mountain I go down on the way to work every morning. In my '04 I would kill the cruse control about 1/2 way down @ 75 and I would be slowed down to the speed limit of 55 at the bottom where the cops hang out. With my '12 if I do the same thing I only slow down to just under 70 as it coasts down the hill.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old December 16th, 2011, 15:55   #35
maxedtdi
maxedtdi's Avatar
I have my own empirical data, since I am averaging about 36.5 in MY tdi.
The 2012 passat DSG is rated at well below the Passat Manual.
A guy chimed in who had both a 6M and DSG confirming my findings.
www.vw.de website lists the DSG and Manual consumption figures backing up my claim.
maxedtdi is offline   Reply With Quote
Old December 17th, 2011, 10:27   #36
ironpen
Smile Claims about manual tranny
Some of you guys appear to be making up claims to fit your story. The manual is rated 1 MPG more...about 2.5%. I have a DSG and I am averaging 38-39 with mostly intown driving and 45 to 47 on the interstate with cruise at 73. I've got no complaints and I have nothing against manual transmissions except the shifting really gets old for me pretty quickly. My friend has a manual and his numbers are similar to mine....on a Jetta. IMO, just get either one that suits your fancy, but don't expect a big penalty if you go DSG. These "gurus" making all the huge difference claims are pushing their own agenda and convincing themselves of their intellectual superiority which no one else seems to be able to pick up on.
ironpen is offline   Reply With Quote
Old December 17th, 2011, 11:47   #37
tdiatlast
Sorry...VWoA, in their specs, says 43 for the manual, 40 for the DSG...unless I'm reading the chart improperly.
Works out to 7%, doesn't it?
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old December 17th, 2011, 12:42   #38
gergg
It's not a big deal....DSG or Manual....just personal preference, both are very economical with the TDI. I don't think people are stretching the truth or trying to prove anything when they state that 6M cars "potentially" get better mpg's......the EPA suggests a 3mpg difference between the two in favor of the 6M, and my experience having had both a DSG and now a 6M is that the 6M enables one to exceed the EPA ratings by a wider margin than the DSG.
gergg is offline   Reply With Quote
Old December 17th, 2011, 13:09   #39
jumpinjoe
New sel model for work commute 50 miles, 80% hwy, MFI indicates 49 mpg.
jumpinjoe is offline   Reply With Quote
Old December 17th, 2011, 21:31   #40
ironpen
Default Tdiatlast
Tdiatlast....you are absolutely correct. My apologies. I was thinking of the Jetta at 42 vs 43 for the manual Passat. I still think some of these claims are made up....but I have proven that I am wrong, so what do I know? I do know I last had a manual on a Nissan Frontier and got so sick of shifting gears after a few months that I started revving that thing up so I could go 1-3-5 and skip second and fourth if at all possible. I drove it mostly in town and it was a real pain in the butt doing all that shifting. Anyway, just my 2 cents worth. If one size fit everyone, they wouldn't make but one tranny....so take your pick. These are great cars and you will love it no matter which one you choose.
Old December 18th, 2011, 08:23   #41
TomB
Fuel Economy: 34 mpg on first tank
If everyone would leave their "mine is better than yours attitude" out of these discussions it would be better. 6M or DSG what does it matter unless you want yours to be the "better" one?
Having said that, what is the lowest speed you can get into top gear on each of these vehicles? With the 2005 Passat you could not below 40 MPH and that was a pain.
What is it for these two, especially the DSG?
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old December 18th, 2011, 10:37   #42
tdiatlast
TomB: I agree with your evaluations of the DSG vs. Manual debate...
As far as the "lowest speed you can get into top gear..." You might want to keep in mind that there are many here that are concerned that cruising in TOO LOW (lugging) an RPM might have a negative effect, causing excessive soot build-up on the CRs...at least, that's my understanding. There may be a penalty to hyper-miling with these engines, with unknown long-term buildup of gook if there isn't sufficient air flow through the DPF/exhaust.
I hope someone with more understanding about this will weigh in...I don't fully understand EGR temps, etc, and how they're affected by lugging...
Old December 18th, 2011, 13:54   #43
Niner
duplicate account, banned
Irregardless of rated MPG, VW's track record on DSG transmissions shifting clunky, mechatronix failures, and 40k mile service gearbox oil changes at $450 a whack, the manual seems a better value all the way around, to me.
Been down that road with an A4 automatic transmission failure before, won't ever be going down it again.
Niner is offline   Reply With Quote
Old December 18th, 2011, 16:09   #44
abctdi
abctdi's Avatar
Regardless maybe???
But this thread is about mpg with DSG, not bashing the DSG.
Start another thread if that is all you want to say.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old December 19th, 2011, 07:24   #45
AstroEng
AstroEng's Avatar
Fuel Economy: 40/48 MPG - Golf, 32/40 MPG Passat
We've had 3 tanks of 100% city streets and they have all averaged 32 +/-1 MPG. That has been with some cold mornings and the wife running the heated seats mostly in the mornings, but throughout the day as well. We also just did a 1300 mile trip up and down I-25 between ABQ and Cheyenne (some mountains, very little flat terrain) and averaged 40 MPG doing 80 MPH most of the time (I think the tank average speed was in the 70s).
I get panicked when I see 30's on the gauge while driving on the highway, but have to remind myself that the Passat isn't my Golf and high 30's is doing great. On some of the New Mexico roads, the Hankooks get noisy (not as bad as the Golf), but on the smooth roads in Colorado, its very quiet. After doing 3000 miles in the golf in October squeezed in with the wife and 2 car seats (I'm 6'1"), the Passat is an absolute joy for road trips. I can stretch out all the way in front of a rear-facing carseat and there is room to spare. Other parents (especially tall ones) will know what I am talking about.
AstroEng
2012 Passat SE w/ Nav (The Wife's)
2005 Golf TDI
And:
My wife's 71 Chevelle that still gets 20mpg in the city... *** America?
AstroEng is offline   Reply With Quote
DSG and Real World Milage whitelite777 TDI Fuel Economy 4 January 23rd, 2013 09:48
Real world MPG - DSG RoadRunnerTR21 VW Passat Family (NMS and B7) TDIs (2012+) 9 January 9th, 2012 04:15
Touareg 2 TDI real world MPG's dfera VW Touareg TDIs 4 December 29th, 2010 15:37
Real world mileage in a 2006 Jetta DSG TDI edgehill TDI Fuel Economy 8 September 14th, 2006 13:05
Real World MPG #s' from AAA rotarykid General Automotive 8 March 21st, 2005 01:35
Page generated in 0.18400 seconds with 11 queries
[Output: 131.92 Kb. compressed to 110.79 Kb. by saving 21.13 Kb. (16.02%)]
