Old May 29th, 2017, 12:14   #1
dtreid
Fuel Economy: ~50mpg
Default Adblue Countdown Timer
I've been getting P2200 NOx sensor malfunction. Cleared it last night.
Went for a drive today and AdBlue countdown started saying 350km until restart not possible.
Adblue tank is full.
Now what do I do?
2012 Passat TDI 120k km
04 Chev 2500 duramax 230k km
dtreid is offline   Reply With Quote
Old May 29th, 2017, 13:53   #2
Rico567
Had this during our second winter with our 2013 Passat. Turned out to be the NOx sensor, all right. And, yeah, we had plenty of AdBlue on board, this particular failure has nothing to do with the amount of DEF. Ours, of course, said 200 miles, not 350 km. Went to dealer, got fixed under warranty, no issues since. I think this is about a US$600 repair, IIRC, so not a good thing.
This has been our only problem with this car in nearlyi 60K miles and 4 years of ownership, so we've no complaints.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old May 29th, 2017, 17:30   #3
dtreid
Is it just a case of plugging the new sensor in? Is there anything that has to be done by VCDS to get the countdown to clear after a new sensor is installed?
Old May 30th, 2017, 03:31   #4
Rico567
A good question. Since ours was replaced under warranty by the dealer, I don't know what they had to do to clear it. Maybe it went away on its own. I've read cases where people have run the AdBlue in the tank down to where they get the normal warning (at 1200 miles, I think), then fill it up and the warning goes away by itself. Whether this 200 mile warning would do the same when the NOx sensor is replace, I don't know.
- Adam Savage
Old May 30th, 2017, 08:05   #5
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
As long as you don't let the countdown get too low, the warning should clear after a few drive cycles with the new sensor. Unfortunately, if it doesn't and the countdown reaches zero, the engine won't start again and you'll have to have it towed to the dealer.
A few people have mentioned a VCDS procedure that will reset it, but I don't remember what it is off the top of my head. Ross-Tech's website will probably have more information.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is online now   Reply With Quote
Old May 30th, 2017, 17:06   #6
dtreid
So this is getting annoying!
Took it to the dealer for a wiring harness recall. They diagnosed a faulty NOx sensor ($950) which they changed.
He forced another regen to reset the system. No NOx codes are showing up, but he can not get the adblue countdown to reset.
The dealership says they don't know what to do now.
I don't what to pay them $150/hr to guess!
Does anyone else have a clue what could be done to get the light to shut off?
Old May 30th, 2017, 17:22   #7
Rico567
<snip>
Well, for starters, don't pay the dealer, demand a loaner, and politely suggest that they call VW for technical assistance.
- Adam Savage
Old May 30th, 2017, 18:07   #8
dtreid
The dealer at least paid for a rental for me to get home after I spent all day waiting at the dealership. I'll give them credit for that.
The service manager said they were going to call VW technical assistance in the morning to see what they had to say. He thought they had run into this problem before but couldn't remember what the fix was.
Old May 30th, 2017, 20:01   #9
dtreid
I just wonder if anyone else has had this problem so that I could offer them some ideas if they come up short tomorrow.
Old May 31st, 2017, 17:11   #10
dtreid
Dealer said they took it for an 80km test drive while forcing a regen.....still no luck! They had better not give me a $2k labour bill for this!
Old June 1st, 2017, 18:11   #11
dtreid
Well I got the Passat back today.
Service manager said they get one in 100 Passats that they can't reset the adblue countdown timer. Says they used tech tips procedure 26-12-01 to fix it.
Happy to have my car back!
Old June 2nd, 2017, 09:14   #12
740GLE
What'd they charge you?
Old June 3rd, 2017, 07:28   #13
dtreid
Dealer ended up charging me for the NOx sensor and install and an additional hour of diagnostic time. He did give me 10% off the sensor and paid for a rental car for me for 2 days. I will say I am actually pretty impressed with the dealer.
Old June 30th, 2017, 21:37   #14
dtreid
Just took the car on a 1600mile tri. Ran great.
Plugged VCDS into it and got a 15733 fault. No CEL
Cleared it and it came back a couple hundred miles later, again no CEL
Not sure why I'm getting this when the NOx sensor was just done.
Other weird thing is that when I pull the code it says Mileage. 0km. Does this indicate some sort of a electrical gremlin? Should it not give my actual mileage that the code was stored?
Can dealer reset mile to start countdown (adblue)? GTSLOW VW Passat Family (NMS and B7) TDIs (2012+) 7 December 2nd, 2016 11:59
Winter Tire Countdown Slowrvr Ontario 101 November 20th, 2011 15:56
Next service countdown jdhunt0 VW MKV-A5 Golf/Jettas 1 February 26th, 2011 17:22
Countdown Timer! cevans TDIFest 2010 2 August 17th, 2010 22:02
The countdown sportsguy Atlantic Canada 11 May 11th, 2007 14:50
Page generated in 0.18352 seconds with 13 queries
[Output: 118.43 Kb. compressed to 98.61 Kb. by saving 19.82 Kb. (16.74%)]
