Spacejanitor
I have a 79 Rabbit with a very nicely done AHU swap that dropped a valve, the AHU short block is rebuildable but the head is junk and will need new head, at least 1 injector and glowplug.
I would like to replace this swap with a 2.0 TDi CJAA engine from the 2010+ Golf/Jetta, here are my questions
is this engine any good? Any known issues that cannot be fixed or that have to be fixed over and over?
Will it bolt up to the 79 5 speed like the AHU?
Can I also upgrade to the 6 speed tranny by maybe using custom CV axles?
Will the 6 speed bolt up to the mk1 locations?
And most importantly, will this engine bolt up to the stock Mk1 locations or will this require fabrication?
Current setup is 97 Jetta AHU(blown) using the 79 accessories like the A/C compressor and alternator using V-belts not serpentine bolted to the original 79 5 speed, water to air intercooler, scirocco radiator, working ECU and OBD2 plug that I use for extra gauges.
Pictures of damage:
http://forums.vwvortex.com/showthread.php?7052850-broken-down-AHU-help
Pictures of damage:
