Sideoiler
- Joined
- May 11, 2005
- Location
- Rancho Cordova, California
- TDI
- 2003 Jetta GLS TDI Wagon, 5-spd, Indigo Blue
ABS and flashing Brake dash lights on my '03 Jetta TDI Wagon...Fixed!!
First off, I have a 2003 Jetta TDI Wagon.
...Well, my ABS and brake light came on just last week for no "apparent" reason...
I cleaned off all four ABS speed sensors and checked their ohm resistance. The front/drivers/left side ABS sensor measured 0. I think it's suppose to measure around 1,000 to 1,300 ohms per Bentley. I believe I'll need a new one...
All the associated brake lines and wires look in good shape, as do the ABS fuses. My battery is clean, although I have not taken it out to look underneath for anything "strange".
Unfortuately, I don't have a VAG-Com handy.
Anything else I should check before I spend some $$$?
Also, any suggestions on the "cheapest" place to get a good replacement ABS speed sensor?
Thanks in advance...
