Highlander
Should the rear defrost button stay pressed in when on just like the hazard button does? Or, does it stay on but pop back out?
Anyone?
Thank you
Anyone?
Thank you
Actually it uses a lot of juice. The switch to the non time delay button happened in 2003 as I recall.
X2I think the rear glass heater uses something like 20 amps of power. That's nearly 250 watts.
-J
Heh you're right on that note.For that kind of power draw it sure doesn't work well.
