jjsbiggs
The blower on a friend's 1999.5 Jetta TDI stopped working in all modes. I pulled the switch and found that I had power to the switch and no continuity through the switch. I replaced the switch and now the blower works in each position but #2. If you use a jumper to bypass the switch you can get the blower to run on each speed. There does not appear to be any continuity through the switch in the #2 position so I picked up a second switch from the junk yard thinking that the first switch was bad but it also does not work in the #2 postion. Can the resistor pack cause the blower not to run only on one speed or am I missing something else?
