Or the new Ford V8 at 3,6 liter and some 275 hp. ...
Ford V8 Diesel to be Made at Dagenham
Ford is planning a V8 version of the new V6 lion diesel engine.
The new engine will be manufactured at Ford's Dagenham engine plant with a planned capacity of 25,000 units a year. It will be assembled in the same hall as the new V6 Lion engine.
Like its stable-mate, the Lion V6, the new V8 is a joint operation. Unlike the Lion, which is a joint venture with PSA Peugeot Citroen, the new V8 has a development partner in the form of International Truck and Engine Corporation (formerly Navistar) of the US. Navistar has its own design for a V6 and V8 engine - the Powerstroke. Ford in North America uses the V8 Powerstroke in its light-duty F-Series trucks, but the V6 Powerstroke has yet to make it to the production line. It has been suspended pending a further decision.
The new Ford V8, designed and developed mainly by Ford engineers in Aachen, Germany, has already been tested. Plans call for up to 100 prototype engines to be built for further development and evaluation. Like the V6 Lion, the new V8 will use compacted graphite iron (CGI) for the cylinder blocks. Tupy in Brazil, which uses SinterCast process control technology, will supply the V8 blocks. The new engine will use features similar to those in the V6, but with some significant differences. The engine is likely to have a piezo common rail fucl injection system from SiemensVDO, as well as twin turbochargers from Garrett. It will retain twin assernbled camshafts for each bank of cylinders, but the drive for the camshafts is likely to be different from that adopted for the V6.
The expected production volume is likely to be modest. At this stage, an annual output of 20,000 units has been pencilled in from an installed capacity of 25,000 units annually. If additional vehicle programmes could be found in North America, volumes could be increased. It is conceivable that the engine could even be manufactured in North America. The V8, with a swept volume of 3.6 litres, should deliver 275 bhp and 575 Nm of torque. These are equivalent to 76 bhpllitre and 160 Nmjlitre. Higher power and torque are possible in the future. Officially, Ford managers, while admitting to a W-engine farnily" in the context of the V6 range, point out there are "no plans" for a V8 turbocharged diesel. (jm)
From the last issue of AutoTechnology - page 11.
( on page 16 more about CGI/Jaguar S-type.)
