Old April 5th, 2014, 15:32   #1
Softrockrenegade
Softrockrenegade's Avatar
Default Trying liqui-moly top tec 4200
Just changed the oil in my passat and decided on this flavor of oil ! Engine seems very quiet ! Anybody else have any experience?
Softrockrenegade is offline   Reply With Quote
Old April 5th, 2014, 15:36   #2
ihatespeed
Fuel Economy: 40mpg city 46 avg, 50 hwy 33 trailer
its what I use, no complaints reasonable consumption, maybe .1 liter per 1000 miles, ie i add the rest of a 5 l jug around the 5-6k mark. and I can get it at the local Napa for about 45-50 a 5l jug..
Andrew's 3rd generation (2Micron.com) return fuel filter, and Pure Flow HPFP modification, timing belt guard and the full Malone flashzilla / Buzzken stage2.0 eco treatment (bosal hitch and heavy springs for towing)
ihatespeed is offline   Reply With Quote
Old April 5th, 2014, 15:41   #3
Softrockrenegade
I had zero consumption with mobil1 esp or castrol slx pro. If I see it burning up I won't use this again. Ihatespeed, is your car burning oil with just the top tec or with other brands also?
Old April 7th, 2014, 09:37   #4
langer
I bought 4200 for my last oil change from napa. Probably burned .75 quart over the 10000 miles oci. Fairly new cr a3 with 35k on the odomoter.
langer is offline   Reply With Quote
Old April 10th, 2014, 19:56   #5
hotpocketdeath
hotpocketdeath's Avatar
I've been using 4200 in my car for the last 30k miles and I have not had any issue with burn off or needing to add more oil.
I plan on staying with 4200 for a long time.
hotpocketdeath is offline   Reply With Quote
Old June 14th, 2014, 14:35   #6
Softrockrenegade
Well I switched back to mobil 1 ESP. My car which hasn't had any consumption up till using the top-tec burned maybe 300-400ml between oci . I'm going to take a look under the car later to see if maybe there is a leak but I don't think that's the case. If I continue to see any consumption with the mobil 1 or it increses perhaps I'll need to check the IC for excessive residue.
Old June 14th, 2014, 14:58   #7
vw_norm
Gone, but not forgotten.
been using top tec 4200 for the last 3 oil changes, ever since i drained the factory load. No oil use between OCI. Only loss is from wiping the dipstick to get a good reading on level.
vw_norm is offline   Reply With Quote
Old June 18th, 2014, 07:23   #8
Cool Breeze
TDI(s): BMW 335D
Btw..switching brands may cause consumption initially but it should stop after the first OCI.
Cool Breeze is offline   Reply With Quote
liqui moly 5w-40 top tec 4100 cobra390t VW MKV-A5 Golf/Jettas 15 September 5th, 2013 12:01
Liqui-Moly Top Tec 4200 amstel78 Fuels & Lubricants 4 February 4th, 2012 09:58
Lubromoly (Liqui Moly ) CERA TEC is now available in Canada Precisiontuning Vendor & GroupBuy items for sale 0 December 13th, 2011 08:27
Liqui Moly Diesel Speed Tec The Weide Motors Kid Fuels & Lubricants 2 November 4th, 2011 18:45
Lubro Moly Top Tec 4200 - 30K? ZiggyTheHamster Fuels & Lubricants 9 May 24th, 2011 09:32
Page generated in 0.14344 seconds with 11 queries
[Output: 85.45 Kb. compressed to 73.21 Kb. by saving 12.24 Kb. (14.33%)]
