Homebrew420
Good morning all been a lurker for a little bit and thank you all for the insight you have given into these vehicles. I really love this car...when it worked. Now it is a bit more frustrating.
A little history,
Purchased in 2017 with 195k mi, CEL was reset before purchase and within 40 miles of me driving came on, car still rean great and was hitting 42-45mpg. Appeared the MAF sensor was bad. Replaced with a cheap one, didnt fix noticed no difference in power or mileage.
The real issue came while driving my brother and my son up to peak to peak highway in the Rockies. Just before we reached the summit it, under heavy load, went into "limp mode" at least thats what i believe. No real boost to speak of. all the lights on the dash came on and after a while of driving as it was, it still got 42 mpg. Just no fun to drive anymore, no boost it seemed. some other issues arose after another 20k driving.
Finally the car began to have hard starts in the morning. My ex wife actually filled with f-ing gasoline. However it started and immediately died. had towed and drained and flushed the fuel system best I could. Filled with a few gallons of diesel and got it to restart, allowing about 45 min of idle and figured there hadn't really been to much if any damage done. Since the car had 240k miles by now I read up and figured I would go through and replace the
timing belt, tensioner, water pump
cam, lifters, guides,
serpentine and tensioner,
glow plugs(light coming on and was getting a code for those with the hard start),
cam and crank positioning sensors
Throttle body
Fuel filter
after all this it now for the first time since I have owned it she throws NO CODES! YEAH! and then sad trombone sound quickly ensues upon a start and immediate shut off.
Since the the key had been giving issues with not responding when buttons for door lock/unlock I thought maybe the cutoff was being activated so I replace the battery, again to no avail.
Fuel pump works. I have witnessed it spitting fuel on ignition turn and can hear the pump as well.
I would post VCSD info...except there isn't anything.
So that's my story. And I know that without codes it is increasingly more difficult to diagnose, certainly from afar.
I have not checked vacuum and was planning to do so but have simply run out of time.
Thanks for your help all
Peace
A little history,
Throttle body
Fuel filter
Peace
