Garythiv
I drive an '04 Jetta Tdi. It's not my first turbocharged car, but my first diesel. In my other engines, I had an experienced mechanic recommend using a fill of automatic transmission fluid in the motor as an engine flush, ie-drain old oil, fill with ATF, start engine for a short (10- 15 mins ) period of 'idling-only' warm-up, then change the filter, and drain and fill with your motor oil of choice. I drove an '89 Mitsu Mirage, and a '94 Eagle Talon AWD both more than 120k km's each, doing the ATF flush every 40K km's or so. Never had any adverse effects, and under the valve cover and the oil-pan were shiny-clean after this treatment. Any thoughts/concerns ? Anyone else hear or do such a treatment to a Tdi motor ? And, no I haven't done it yet to mine.
