hey guys, got another crazy one here...
Last Friday I had it at home putting trailer hitch and all on it, in that time the battery got low from doors and what not being open and wouldn't crank. I hooked my cummins to it, fired it right up. But I did notice glow plug and TPMS lights flashing. So, I said well I'll run it around the neighborhood hood so wheel sensors will relearn. TPMS light went out but noticed it had no power and is in what feels like limp mode. Hooked scanner to it and has no codes. I tried re tuning with my Malone file again just to make sure it didn't do something weird when the voltage got low, but still in limp mode, no check engine light or anything. Tried driving it today after unplugging the DPF pressure sensor and i noticed glow plug light is blinking non stop now, so hooked my scanner to it and its got a P0237 low boost code in it that absolutely will not erase. Pulled sensor and cleaned just incase but it looked fine and not covered in anything. I cant see a sensor going bad out of no where just from battery voltage getting low. I also overnighted a VCDS system last night to see if it would delete the code. Its never done this, has been running flawlessly. Is there anything you can think of that would cause this from what happened with battery running low on me? Thanks in advance!
