whitebeemmmuu
Hi All,
Im new to forum and am seeking assistance with a 2015 Audi Q7 Quattro TDI 3.0L heated Lamda Sensor. My VCSD is currrently reporting an engine fault as follows.
Is the sensor that is being flagged (B1S1) the one up top of the vertical catalyst?
Oxygen (Lambda) Sensor B1 S1
P2237 00 [232] - Pump Current Open Circuit
Here is a link to picture of the Exhaust sensors on the 3.0 L Q7. Although MINE is slightly different, maybe it is because of the updates applied to the engine because of diesel-gate... My car has been retrofitted, whatever that means is unknown.
https://audi.7zap.com/en/rdw/audi+q7.../253-253050/#1
In the diagram, the #6 part is the lambda sensor. My car has two sensors on the input to the catalyst, both similar but different, but definitely O2 type sensors.
The connector to the first sensor sits on the firewall and is very accessible and the wires look fine. Im not sure how they could be any better thatn what they are. There is no sign of damage or stretching... and the length of the harness is at most 24". The lower one, inches away, goes to the driverside area to another plug... and looks unscathed.
Here is the full VCSD dump:
Code:
Wednesday,03,June,2020,18:56:05:32711
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
VIN: WA1LMAFE9FD0abcdef License Plate:
Mileage: 97970km-60875mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1LMAFE9FD0abcdef Mileage: 97970km-60875miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H23 0012
Revision: 54H23--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 30836 003 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 221DE85754480D6B65F-8076
10 Faults Found:
5211 - Fuel Rail/System Pressure
P0087 00 [032] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
4484 - Coolant Thermostat Valve (N214)
P0128 00 [096] - Temperature below Control Range
5104 - Oxygen (Lambda) Sensor B1 S1
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 84
Mileage: 90878 km
Date: 2020.02.15
Time: 20:46:00
Engine speed: 700.50 /min
Normed load value: 61.2 %
Vehicle speed: 0 km/h
Coolant temperature: 89 °C
Intake air temperature: 41 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.220 V
Unlearning counter according OBD: 40
Air mass: actual value (mg/stroke): 368.5 mg/stroke
Mean injection quantity: 13.47 mg/stroke
Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7: 1
O2 sensor 1: bank 1: voltage raw value O2 signal: 3.8 mV
O2 sensor 1 bank 1: voltage reading Ri-signal: filtered.: 1020.4 mV
O2 sensor 1 bank 1: duty cycle O2 heater: 39.99 %
LSU r O2 Adap 0: 0.00224
38161 - Reductant Metering Module
P20FE 00 [096] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 88735 km
Date: 2020.01.29
Time: 08:36:47
Engine speed: 1575.00 /min
Normed load value: 55.3 %
Vehicle speed: 95 km/h
Intake air temperature: 36 °C
Voltage terminal 30: 14.080 V
Unlearning counter according OBD: 26
Outside air temperature: 31.0 °C
Pressure sensor for reducing agent: measured pressure: 5142 hPa
SCR catalytic converter average temperature: 302.6 °C
Sensor for reducing agent tank temperature: temperature: 28.0 °C
Reducing agent pump: activation: 50.00 %
SCRPOD p Cns De Mon Avrg: 772 hPa
9952 - Catalyst System; Bank 1
P0420 00 [096] - Efficiency Below Threshold
31982 - EGR Valve (N18)
P0403 00 [032] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97635 km
Date: 2020.05.31
Time: 17:56:31
Engine speed: 1275.00 /min
Normed load value: 0.0 %
Vehicle speed: 43 km/h
Coolant temperature: 92 °C
Intake air temperature: 45 °C
Voltage terminal 30: 13.940 V
Unlearning counter according OBD: 38
EGR Vlv i Eff Flt: 29.64 A
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 85.66 %
EGR valve: offset closed: -0.18 %
High press EGR actuator: actual unconditioned volt val: 1290.2 mV
EGR valve: offset open: 0.18 %
31983 - EGR Valve (N18)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97635 km
Date: 2020.05.31
Time: 17:56:30
Engine speed: 1289.00 /min
Vehicle speed: 44 km/h
Voltage terminal 30: 13.880 V
EGR Vlv i Eff Flt: 29.66 A
EGR Vacuum Regulator Solen.val.: activation: 0.00 %
EGR Solen.val.: actual value: 25.40 %
High press EGR actuator: actual unconditioned volt val: 3347.8 mV
26254 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [096] - Signal too High (Rich)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 94198 km
Date: 2020.04.21
Time: 11:42:33
Engine speed: 1658.00 /min
Normed load value: 16.5 %
Vehicle speed: 100 km/h
Coolant temperature: 66 °C
Intake air temperature: 34 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.100 V
Unlearning counter according OBD: 39
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
21227 - Fuel Trim; Bank 1
P0172 00 [232] - System Too Rich
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 93668 km
Date: 2020.04.16
Time: 15:03:00
Engine speed: 1576.50 /min
Normed load value: 36.9 %
Vehicle speed: 96 km/h
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.160 V
Air mass: actual value (mg/stroke): 276.6 mg/stroke
Standardised airflow ratio: 2.1451
Ambient temperature: 27.0 °C
Mean injection quantity: 5.88 mg/stroke
O2 sensor 1 bank 1: O2 sensor actual value: 1.001
Pressure control valve adaptation factor: 1.0784
21232 - Fuel Trim; Bank 1
P0171 00 [100] - System Too Lean
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97000 km
Date: 2020.05.28
Time: 12:44:41
Engine speed: 1416.50 /min
Normed load value: 13.7 %
Vehicle speed: 58 km/h
Intake air temperature: 47 °C
Voltage terminal 30: 14.000 V
Unlearning counter according OBD: 57
Air mass: actual value (mg/stroke): 586.3 mg/stroke
Standardised airflow ratio: 1.0294
Ambient temperature: 32.3 °C
Mean injection quantity: 5.30 mg/stroke
O2 sensor 1 bank 1: O2 sensor actual value: 32.767
Pressure control valve adaptation factor: 1.0846
Readiness: 1 2 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 3399
Serial number:
Coding: 001378
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7BA3F53393629CA3069-802E
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099441
Shop #: WSC 31414 790 00001
VCID: 34311E0FF23C93DB873-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902203510
Coding: 0000135
VCID: 2517F34B49E6FA5300D-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H05 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
5 Faults Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 17
Reset counter: 106
Time Indication: 0
00191 - Passenger's Door Handle Touch Sensor (G416)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 19
Reset counter: 25
Mileage: 93618 km
Time Indication: 0
Date: 2020.04.12
Time: 09:13:17
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 99
Mileage: 79345 km
Time Indication: 0
Date: 2019.11.08
Time: 19:19:47
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 241
Mileage: 96572 km
Time Indication: 0
Date: 2020.05.25
Time: 20:33:41
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 254
Mileage: 95204 km
Time Indication: 0
Date: 2020.05.04
Time: 12:12:01
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000030383481
Coding: 0302A036
VCID: 2517F34B45E6FA5300D-8070
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0139123
VCID: 6E85CC67DC90F90BB17-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931509701625
Coding: 25011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311E0FFEBC93DB873-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90SWTJ
Coding: 0014131
VCID: 2B0305732F02CC23D69-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME5F53195AS
Subsystem 3 - Serial number: 6342QSME62531C52C
Subsystem 4 - Serial number: 6352QSME33584A4AO
Subsystem 5 - Serial number: 6362QSME595302428
Subsystem 6 - Serial number: 63734SME24534264V
Subsystem 7 - Serial number: 63834SME27534558+
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026150720469
Coding: 0012042
VCID: 2809FA7F3EF4E73B3BB-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2S51ML4G
Coding: 8BD664040100CF05020205
VCID: 42DD48D7B4882D6B05F-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M154130690
Coding: 00C303
VCID: 3FDB4123C77A40836A1-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 32098D24034121722263
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AD
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---012 Serial number: 00000000474070
Coding: 0000006
VCID: 6889BA7FFE74273BFBB-803C
1 Fault Found:
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 66846 km
Time Indication: 0
Date: 2019.07.01
Time: 19:23:48
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000142886738
Coding: 00581B00000011110000
VCID: 323D181704289DEB95F-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E050C671C10B90BF17-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H03 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F11.04.1500H03000AMS12763ÿ
Subsystem 4 - Serial number: S12763ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000145801376
Coding: 011F57205E40440004
VCID: 48C95AFF92B4073BDBB-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82010010610000
Coding: 3569949
VCID: 38292A3FEE5477BBABB-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000078620
Coding: 030000
VCID: 290FFF7B29FEDE33245-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191097818
Coding: 0758477
VCID: 2313ED5347D204636E9-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H17 0100
Revision: Serial number: 00000000230187
Coding: 0012001
VCID: 5EE59CA72C30698B017-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000145805680
VCID: 47CB59C39FAA0843D21-8012
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0020
Serial number: 150420-0002-123
Coding: 1147A71010020400
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD48D7B4082D6B05F-8016
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156D-0F8253092
Coding: 020007010000000000
VCID: 2411EE4F4EDC035B173-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 G HW: 4L2 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 513D$0F7517519
Coding: 180200060004E3EF510023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130DU0F3327178
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002244663
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000146204658
Coding: 010E57204040230004
VCID: 46D554C798A0114B297-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000366444581
Coding: 0200000000000000
VCID: 313F171B012EA6F3EC5-8064
1 Fault Found:
02539 - Terminal 30 from Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 94652 km
Time Indication: 0
Date: 2020.04.25
Time: 14:31:56
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H09--- Serial number: 525PA8-JA3423W
Coding: 1021101
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C66FEA8C0B1B9F3-8038
Subsystem 1 - Part No: 4L0 910 946
ó[1]
Subsystem 3 - Serial number: RD13.04.15--H58001002E0226ÿ
Subsystem 4 - Serial number: 2E0226ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0145635128----
Coding: 0003595
VCID: 2615F44734E0F14B097-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000146204657
End----------(Elapsed Time: 02:12, VBatt start/end: 13.1V/14.0V)-----------
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 4L2 910 401 A HW: 4L0 907 401 E
Component and/or Version: 3.0TDI FSA H23 0012
Software Coding: 2A2A4012253600050000
Work Shop Code: WSC 30836 003 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001013 (AU56)
10 Faults Found:
P2237 00 [175] - Pump Current Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 85
Mileage: 90878 km
Date: 2020.02.15
Time: 20:46:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 88735 km
Date: 2020.01.29
Time: 08:36:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97635 km
Date: 2020.05.31
Time: 17:56:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97635 km
Date: 2020.05.31f
Time: 17:56:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 94198 km
Date: 2020.04.21
Time: 11:42:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 93668 km
Date: 2020.04.16
Time: 15:03:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97000 km
Date: 2020.05.28
Time: 12:44:41
Readiness Status: 10000010 00001111 11101011 00000000
MIL Status: MIL ON
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 2
Address 01: Engine
Advanced Identification/FAZIT
Serial number:
Identification: RB8-658
Revision: 54H23---
Date: 01.04.15
Manufacturer number: 1409
Test stand number: 0341
Flash Status
Programming Attempts(application): 0/1/1/1/1
Successful Attempts(application): 0/1/1/1/1
Flash Date: 00.00.00
Misc.
Hardware number: 4L0 907 401 E
Workshop System Name: J623
ASAM Dataset Revision: 001013
Car Info
Chassis Number: WA1LMAFE9FD0abcdef
Engine code: CNRB
VCDS Info:
Readiness: No script available
Address 01: Engine
Serial number:
Revision: 54H23---
Date: 01.04.15
Flash Status
Misc.
Car Info
Engine code: CNRB
VCDS Info:
