Mikkijayne
Aha! If the case pressure regulator is differential rather than absolute then that makes things a lot easier.If you look carefully u'll notice that the pressure regulator for the case pressure builds a certain pressure differential over the pressure at inlet of the pump. So if u increase pump inlet pressure case pressure will rise just as much and timing piston will see no difference at equal n108 duty cycle.
FUB - those are motor mounts. I have a feeling Jon's vision is going to get a little blurry if they're anything like as stiff as 034's equivalent
