turbocharged798
I always thought it would be nice do DIY pop test and calibrate my own VE injectors. Found this via google.
http://www.peachparts.com/shopforum...334-how-build-diesel-injector-pop-tester.html
Would that setup work on TDI injectors too? I know they run at much higher pressures than IDI injectors so I wonder if a 2 ton bottle jack would have enough umph to drive them.
Also, how hard is it to shim and calibrate them with a rig pictured above?
