jettyknight
I just had mine replaced @ 55K under warranty. '06 with DSG
b1llyb0y said:Having mine replaced as I write this .. 160,000 km ..
AUD $1580 for DMF. plus labour.
anut (Anuthee) is in colorado. Runonbeer is in Austin. He and I worked together on replacing my DMF.TonyJetta said:There are several listed.
IIRC, user anut is local to houston. But, double check.
Tony
I did the same thing. Bought the parts from BB and started late Saturday morning. Quit that night when I got the transmission put back in, buttoned it up Sunday AM and drove 500 miles that same day. Huge difference. Have beat the hell out of it since and it's been great. About 20k miles on the new one now. (mine was also the *new* part number)keyfarms said:Hey guys, I just replaced my DMF last week. Did it in my garage about 10 hrs total time. Got the flywheel from Bora parts for 678.00 plus overnite Fed EX. This was a BIG JOB. But the pics and info on this thread was priceless!! Mine started vibrating, its been rattling for 2 yrs. though.. Anyway all is well.. It had 335,000 miles on it thanks Allen
I'm getting ready to replace the DMF im my 06 Jetta and I'm wondering how important the ratcheting wrench adapters are? Also, does the Bentley manual provide any useful info other than torque specs? I found that a lot of the info in my A4 Bentley manual is vague and generic (eg. how to replace the alternator) It basically says remove the belt, electrical connections and mounting bolts and remove the alternator. They forgot to mention that the tensioner is in the way and so is the rad hose.abakos said:The hardest part is getting all the right tools ahead of time. You've got to have the triple square bits, and I can't remember who suggested it but the ratcheting adapters for box wrenches are brilliant. I had never seen them before, but I found a set at Northern Tool for a very reasonable price!
You're probably stuck with the tab on this one, regardless of letterheads.Debaser42 said:Hi - I joined the forum after finding some threads on the DMF issues. My flywheel is cracked and luckily I got it in before it ruined the entire drivetrain. However, because I'm at 69k miles (69k babied, vw serviced on time, one owner miles) VWoA refuses to pay for it.
From my understanding, VW knew that this part was faulty and decided against recalling even though it was known to fail at a high(er) rate than normal (from my understanding a flywheel should last the life of the car - aka 100k-200k miles at least).
So, I've lodged a complaint with VW, and they don't care, and now with NHTSA (who probably won't care) and I'm calling a lawyer cousin to see if I can't use his legal stationary )).
Any suggestions (I tried searching but this seemed to be the best thread) of what else I might do to get them to pay? I guess I'm one of the lucky ones who got away with only $2k worth of damage but I'm still paying on the car and this makes me really unhappy.
I don't pretend to be an expert, but I have done the job and read every thread I could find on it.YODAUSA said:In just had the failure, My wife and I packed up the 2006 Jetta 66,800 miles. last night. 8am this morning started south on the Kansas Turnpike headed to warm weather in Texas. About 25 miles from Topeka running 70 mph, it suddenly down shifted to 5th gear and the rpm of course went up. I caught it before to high of rpm. It started a grinding sound, I took a chance and turned back on the turnpike through one of those Highway Patrol turn arounds and babied it back toward home. At each long grade, it down shifted to 4th and a lot of grinding noise and loss of power. I feathered the throttle and ease it to the top of the grade and as we went down it shifted up the 6th again. Each timel, my wife and I praying to keep going, I would have pulled over and got a tow truck, but it was minus two degree's outside and we were a distance from any town when it happened.
For the record it is a 2006 Jetta66,800 ,miles, I purchased as the second owner. When it was delivered I noticed a little noise under the hood, it sounded like two pieces of metal shrouding knocking together, never suspected a tranny problem. I am 68 and I have never heard a transmission make noise like that. It's Saturday so I will not know anything until Monday... I wish there was a Guru close by or ABAKOS seems to know what he is doing. I can't believe VW would put a vehicle on the road with that kind of problem. I have had 5 Buick Park Ave with the 3800 engine, drove all of them to 150,000 and all were excellent dependable vehicles... I guess I really screwed up giving up a dependable brand to go to the Jetta.. Shame on me..
I did bring the car in right after I purchased it for the transmission fluid change at 57 or 58 thousand miles... I told the SERVICE MANAGER to check the metal rattling under the hood and see if he could determine what or where it came from. When I picked up the unit after the filter and fluid change he told me he couldn't determine where the noise was coming from. Sounds like a coverup perhaps... I am going to have to pull the orginal work order with that noise indicated on the work sheet before I call VW America.
Anyone else have any suggestions??????? Thanks You John
Actually my alignment was good after the job, but you should still check it. Sears checked it for me and determined that it was fine, so no chargeMach1 said:Did mine the other day, tried to get the dealership to replace the clutch pack, because the reverse shudders badly, no go.. Oh well got the good DMF..
Yes, you have to lower the driver side lower control arm, which messes up the alignment, Guess what VW says you can get it close, so they dont pay for an alignment.
Still have a reverse shudder and an out of alignment front end AND SOMETIMES A FALSE NEUTRAL..
I will fix it..
