Frostheater Operation Question
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
I recently installed a Frostheater(FH) on my MK4 ALH TDi.
The install was quick, easy and painless. I lost MAYBE half a gallon of G12(being extremely cautious and mindful)
After the install, I topped off the coolant(slightly over Max) and drove around for nearly 50 miles, without shutting down. FH Suggests 30 miles before testing the heater. Naturally the system used some to fill air gaps maybe and I am now right below MAX, perfect.
So, I "tested" it this morning. Plugged it in, checked to make sure it wasn't smoking or starting a fire.. Checked acouple more times, then, i didn't come back for nearly 4 hours. after 4 hours I unplugged my FH, Popped my hood and boy was it WARM!(nearly HOT, or very WARM) Valve cover, coolant hoses, everything up top was nice and toasty @ 40° outside. COOL!!!!!
now to the question:
**The FH unit was making an almost boiling sound, or maybe hissing**
*Is that normal, have any of you users noticed that noise?
**How can I make sure my coolant is circulating properly to avoid frying my new FH?
I love the idea of having it, even for chilly mornings! and I want to make sure it functions properly. I figured id ask some hands on users, as opposed to emailing FH about a simple question. I'll Email them if you guys dont have any similar experiences. Thanks!
Cleaned up the plug in with a Marinco 150BBIW
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
So long as it's got coolant in the system it SHOULD never boil dry,
It does sound like a kettle boiling but should never sound like a rolling boil.Sounds like pop fizzing
Just enjoy your winter ready car!
Definitely didnt sound like a rolling boil, but ill keep an ear on that.
Tomorrow will be the first test where I will actually be driving. It'll be in the mid 30's and normally I would idle my car for 10 minutes in the apartment complex parking lot before setting off for work.
Thanks for the reply!
Duke_962
Northern new jersey
2003 jetta 5spd
Have nearly same bumper plug in mine to keep it clean looking. I have mine setup to a high amp timer to kick it on 3 hours before I leave in the am. The frost heater was the first thing I did when I got the car and worth it. Nice install.
scooperhsd
Kansas City KS
NB, 2000, RED(5 Speed conversion) 2015 Golf SE
WHY would you idle for 10 minutes before driving off, when it has been proven that the most effective method to warm it up would be to start, wait until it's smooths out (usually about 30 seconds - a minute or two), then drive off ? As long as the proper oil has been used, it will be everywhere it needs to be and flowing within 5 - 15 seconds.
Adding a frost heater is more of a comfort thing than a necessity in the lower 48 (unless you're see -35 or colder on a regular basis).
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
Well, several ways to answer this.
One, its documented my car uses a quarter of a quart per hour to idle, that isnt much...
Two, I live within 2 miles of the interstate and it isnt good for the valves to rev high while cold. If I crank up, wait 60 seconds and drive to work they would be cold and doing 70+ mph( higher rpm) for many miles before budging on the gauge....
Three, the car gives me full heat only acouple miles down the insterstate after idling. Without the idle, that is extended(again the creature comfort part of this)
I totally agree that this is for my comfort. Although, it is better for the motor to be near operating temp, as the computer send fuel differently based on operating temp...
Sent from my VS987 using Tapatalk
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
Next step is getting the timer, but i intend to do the same.
Votblindub
NY
MK4 Jetta Wagon
My FH is silent.
I wouldn't idle that engine that long, they don't really warm up like gassers do. Fire it up, check your mirrors, put on your seat belt, plug in your phone or put on some music and just set off. It warms up when driven.
JDSwan87
Black Swamp Thing
Michigan near Toledo
2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
My FH is silent.
This!... my FH runs for 4 hours before I leave. I get in and follow this exact same process for my 9.5 mile drive.
coalminer16
Central Wisconsin
Golf 2004
It is key to have the heater at the lowest point. Heat rises which is how the flow part works.
On my 81 rabbit diesels that Terry made a kit for me I could actually get it to defrost and melt snow off the windshield if i left the defrost vent open. The heater will get the temps up to around 210 I have seen if plugged in all shift at work. Not a required to have one of these but it is easier on the starter, battery, lub system, glow plugs and the driver. I had my 04 golf start on fire with a really cold start after night shift. Shorted out near the starter. They didn't have plugins. My new location does so I just ordered a heater for the 05 golf now that I can use a plug and am back on nights again.
Sent from my SM-G950U using Tapatalk
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
It is clear that with the FH, i no longer idle AT ALL, right? lol
Prior to installing my FH, I DID idle, and I can notice a difference between idling and not idling~ and which exit on the interstate I'd reach 190 degrees, as I passed.
Also, I am not arguing that Diesel's are or are not thermally efficient. I'm just stating that idling does make a difference for the creature comfort focus.
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
* Should it be sitting lower than the lowest hose?(slight downward slope from the oil cooler into the FH?) *
I hadnt seen any particular statements on that but had read that the FH's mount may need adjusting, and the Power steering bracket may as well.(PS is no issue)
belome
Mid MI
2002 Jetta GLS TDI 5-speed
I'd bet an hour at 30 degrees would be plenty... keep in mind, it isn't free to run.
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
It's essentially a water heater if you listen to your water heater when it heats, you will hear the same thing, just like sticking a kettle of water on an electric burner in the kitchen.
Water has to reach 212 to boil and the boiling point of coolant is a good bit higher than that, especially under pressure as the cooling system should be.
