dasjefe
I have a 2015 sportwagen. Installed a Westfalia tow bar kit this weekend. Everything went ok, but now for some reason the hatch reports on the instrument cluster that it is open (it is not) and it cannot be opened remotely or with the external handle. I checked the 7.5a fuse for camera/hatch (F18 I think?) and that looks ok. If you manage to trick it into thinking the hatch is closed via manipulating the latch the backup camera does work. I'm kind of at a loss here. I am under warranty, so I can take it in I suppose. I initially had a couple of errors after the tow bar install (TPMS and Stability Control) but those went away after driving the car a bit - and I suspect this was simply due to having the battery disconnected. No errors relating to hatch or similar in my VCDS scan. Any ideas?
