Herm TDI
- Joined
- Nov 21, 2001
- TDI
- 2002 Golf GLS Malone Stage 3, P+520 nozzles, 11MM Inj pump, Sachs VR6 clutch, Stelth Race Pipe, Immo Deleat, EGR Deleat
Car Info:
2002 Golf GL TDI w/ 5-Sp manual
Perf. Modifications:
Stage 3 Tune w/ EGR delete
11 MM Inj Pump W/ PP 520 nozzles
Stealth race pipe
The Problem:
About two years ago I noticed a steady drop in my MPG. I have no active DTC's
I went through the usual checks.
The static & dynamic timing were "spot-on"
Wheel alignment were well within tolerances .
Tire pressure has been unchanged since I've own this car (32 PSI on all 4 corners).
Air cleaner replaced (my preferred brand Mann w/ snow guard layer)
Fuel filter replaced (my preferred brand Mann)
Checked and checked again no dragging parking brake.
Replaced the MAF (still no change in the low MPG)
Replace the Eng Temp sensor (OE)
This went on ...I continued to ponder this matter. My MPG in normal summer driving condition was in the high 30's and some times into the low 40's (MPG).
I started to look into the parameters that the ECU uses to compute the fueling maps... Throttle position sensor, Fuel temp sensor, MAF , MAP and the ambient air temp sensor.
I was rooting through VCDS to check these #'s output to the ECU.
Then I found an odd reading...the Ambient Air Temp (AAT)sensor. This sensor is one of the vital fueling inputs .
I was reading a constant -2.2 Celsius (28F) in late June !!!
The Aaaahhhaaa moment !
Here I was driving around in June and the ECU is fueling the engine for February weather !
I replaced the AAT sensor and my MPG went up to 46 MPG over the next fuel fill of the tank .
NOTE:
I never once had a DTC for a faulty AAT sensor .
Stealth race pipe
The Problem:
NOTE:
