So I was changing an IP and TB on a 96 passat. The pump was rebuilt from DIS in portland. It took a long time to get this thing running because the adjustment to advance or retard the timing of the pump was reversed. Unless I have missed something your suppose to pull the pump toward the front of the car to retard timing and push it to advance. This one was opposite. Is this normal on this car? This is the first one I have had to adjust the timing on since the ones I have done in the past haven't had to be adjusted after the TB.
Thanks for any info on this.
