RamMan4x4
Glad to hear everything is working...I wish I could give you some advice on the reverse gear, but I don't have much knowledge on these transmissions. Hopefully someone else will chime in...
EDIT: Oh and I agree with your choosing loctite over the bore and pin/weld method...while that method may ultimately hold better if done correctly it would be nigh impossible to get it correct without removing the tranny from the car and the main shaft from the transmission. Not to mention drilling into hardened steel shafts. You did the right thing...hope it continues to hold!!
