GlacialFlower
I have read and read about this and there never seems to be an ending to the story (post).
The car drove well. I reached my destination after a 250 mile trip.
-The next day there was no fuel in the supply line when there is usually fuel + small air bubble. Nothing in the injector lines either. dry as a bone.
-It will not prime. I replaced hoses with clear ones and stuck both lines in a gas can of diesel. nothing.
-Changed seals except for shaft seal even though it never leaked.
-GP and CEL come on at start. I pulled fuse 32 and turned key on and they did not show up. So, I assume relay 109 is good.
-I loosened the connector on the pump, but did not take all the way off. Did I do something detrimental?
1. Can it possibly be a short somewhere and not actually the IP? I tested resistance on the IP plug and they are all within spec.
2. I checked the resistance to the crank sensor and it was good.
3. Is there anything simple/specific I can do/test to eliminate pieces and parts?
4. I have read about Ignition issues. Is that issue usually in the steering column?
I just don't want to dig into another pump and have it be something simple.
thanks,
GF
VCDS was purchased after the car crapped out so I have nothing to compare, but here are the results from modules with faults:
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G000SG 4102
Coding: 00002
Shop #: WSC 00000
VCID: 57EB8EBC86156A2FD8D-4B3D
4 Faults Found:
17971 - Quantity Adjuster (N146)
P1563 - 35-00 - Lower Limit Reached
17762 - Modulating Piston Movement Sensor (G149)
P1354 - 35-00 - Electrical Malfunction
16567 - Fuel Temp. Sensor A (G81)
P0183 - 35-00 - Open or Short to Plus
17946 - Fuel Shutoff Solenoid (N109)
P1538 - 35-00 - Open or Short to Ground
Readiness: 1 3 0 0 0
Part No: 6Q0 909 605 F
Component: 08 AIRBAG VW6 0202 0004
Coding: 12344
Shop #: WSC 00000
VCID: 3A2D370815479747C73-5161
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 07232
Shop #: WSC 00001
VCID: 313F1024C831541F769-5161
9BWGP61J724024866 VWZ7Z0A3996687
2 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00000
VCID: 70B9D52003BB1D17397-5161
2 Faults Found:
01304 - Radio
thanks,
GF
Coding: 00002
Shop #: WSC 00000
4 Faults Found:
Coding: 12344
Shop #: WSC 00000
1 Fault Found:
Coding: 07232
Shop #: WSC 00001
2 Faults Found:
01304 - Radio
Coding: 00006
Shop #: WSC 00000
2 Faults Found:
01304 - Radio
