Not every shop or individual named in this thread makes it to the "recommended" list. A single mention rarely leads to inclusion. So an advanced search using your state's or city's name as a keyword might help you find other choices besides those on the official list.Hey guys looking for mechanics... have you checked the list first? That is probably your best bet. Good luck!
I did stop by L&S sales today and Jason hasn't been there in a couple years.You're not too far from the super TDI-Techs in Montague, NJ (Hevster1) and Port Jervis, NY... (TDIJetta99)
Yuri
Ok, good. I took my car to John a while back and he was great. I had him do an oil change and he seemed like he knew a lot about VW cars in general, TDIs in particular.Took my Audi there for a timing belt service, ~ 3k miles later
the belt snapped, destroyed the engine. Apparently had a Volvo tech doing
timing belt services. Towed the car back and they let it sit for about 2 months until I pressured them to fix and suddenly it wasn't the untrained Volvo
techs fault but something else that seized, (isn't that convenient, after it sitting
in their lot for so long). Then they tried to make an offer to buy the car for junk price.
Come on over and meet with us, we'll take care of your 40K service, no problem!Ok, good. I took my car to John a while back and he was great. I had him do an oil change and he seemed like he knew a lot about VW cars in general, TDIs in particular.
First issue I had with him was I gave him all the supplies to do an oil change and fuel filter change. However, when I asked to see how dirty the fuel filter was, he couldn't produce the replaced filter. (This was when he was working at different shop.) It was an awkward moment so I didn't press to see it. He said he had somewhere in the shop.
So now, I believe he's running his own shop and has a couple of guys working under him. I took my car there for subsequent service and even had my gf's car serviced a couple of times, too.
My last service was for a brake job, oil change, and front suspension work (left front spring snapped for some reason). I believe, all work was done by another mechanic that worked for him. I complained to this mechanic that the car was vibrating (not the steering wheel). This mechanic tells me it's probably the warped rotors. So he changed all of them. How John didn't tell me my brakes were close to getting warped on my last service, I don't know. But, whatever, I just wanted the vibration to go away. (I only drive this car on the weekends, btw.)
Brakes were changed, front suspension was changed. I even received a discount for being a TDIClub member and having more than one car when it was time to pay.
But, the vibration was still there. The new brakes were blamed. The new suspension was blamed. I even started thinking I was just imagining it or it's just the car getting old (about 70K mi at that point). Even my mpg started dropping.
So, anway, I took the car to a stealership for a recall after a few months of my last service with John's shop.
Stealership informed me that I had a bent rim in the rear and my alignment was way off. On top of that, one of the rear tire was worn to the steel. Kinda explains the vibration.
I suppose this was my fault as I should've known to get an alignment after the front suspension work but still...
In short, I will not be going back there. In process of setting something up with left lane cars in Irvington for my 80K service. Or maybe say **** it and just get it done at the stealership.
Anyways, anybody have good/ bad stories from leftlanecars?
I use H&B Motorworks in Chesapeake Virginia. I have 225,000 miles on my 2011 JSW and they have been great.Hi, Is there anyone in the Norfolk, VA area or within 20 minutes? I have a 2000 Jetta that I need some advice on or if they can take a closer look at it.
Hopefully it will be some time before I need one, but thanks!I use H&B Motorworks in Chesapeake Virginia. I have 225,000 miles on my 2011 JSW and they have been great.
What did he say?? Did I miss something??Growler's TDI Service has been removed from the trusted TDI mechanics list by request from the proprietor.
Thanks for your many years of TDI service, Aaron!
Robbie -TDIClub member "runonbeer" - in Austin is the closest to you.Hi all. Posting again. Are there really no trusted TDI mechanics in the Houston Texas area?
http://forums.tdiclub.com/showpost.php?p=4847951&postcount=133What did he say?? Did I miss something??
Do some research/call around? I'm sure others would be thankful if you discover a good shop to add to the list!Thanks Sailor! That's still about 3 hours away though. Just would've thought as large as Houston is, that there'd be at least one or more here. I do appreciate your reply though. Have a great day!
Vacation? What's that!?!? Lol.Can't say I blame him. I work seven days a week.
Still, people get pissy with me about a 2-3 week wait to work on their car.
My "vacation" a week ago was cut from 7 days to 3. Had to appease a couple of "children" and then the ban hammer came out.
right!Vacation? What's that!?!? Lol.
