All 4 Cylinders - Internal Pressure Sensor Fault
kruxpavilion
Canada
2012 VW Jetta SportWagen 2.0 TDI
Hey everyone,
I am hoping to get some insight into this issue that has been plaguing my 2012 Sportwagen for about 4 months now.
In around November, I got an engine light. It was after a really cold snap. I grabbed my dad's VCDS cable and diagnosed it. I'm still trying to find the log file I downloaded... It's around here somewhere. If it really helps that much, I'll do a re-diagnosis tomorrow and I'll post the log file here - but I'd like to start brainstorming.
I got P13D7 along with the same type of error for every other cylinder - internal pressure sensor fault. It was specifically "Short to Plus". So obviously, there's a short somewhere. Is the short just slightly out of the parameters acceptable by the ECM? Some oddities: every time the weather got slightly warmer, the engine light would disappear. Very strange. When the weather got colder again, the engine light would reappear. (Specifically above/below freezing)
Other notes: the glow plug warm-up indicator on the dash seems to be operating normally - I don't have any kind of issue with my glow plugs themselves as they seem to be warming the cylinders properly. Is this indicative of something else being wrong? The harness (from my understanding) wraps around a huge chunk of the vehicle, and the process of following the entire bundle to check for shorts would be crazy.
Additionally, I've recently removed a piece of crap chinese aftermarket radio from the vehicle as it wasn't reliable and put back the old unit (which is an rcd 310 I believe). The short to plus issue didn't occur immediately after installation but it did seem rather coincidental.. Could the radio have ruined something internally?
I've checked all of the fuses - no apparent damage or issue there. I've checked connections to the battery and they seem fine. I've checked wiring to the old radio and there aren't any shorts or issues.
I just don't know where to begin looking. I find it very unlikely that all of the glow plugs need to be replaced. Are they wired in series? Could the first in the series be effecting the rest of the plugs?
Honestly any help/suggestions would be greatly appreciated, I am a plumber by trade - not an electrician! :)
Thank you
oilhammer
outside St Louis, MO
There is a TSB for this, but the basic part is to view the cylinder pressure sensor values while moving the connectors on the glow plugs, to see if there is any changes. You may need to splice in some new connectors, or in some extreme cases, a whole new engine harness.
Check Group 141 in VCDS engine data and see what you find.
kruxpavilion
Canada
Sorry, a TSB?
Okay I will do as you advised... I'll try to move the connectors around to see if those values change. I believe they were all stuck at 255...
When you say a new harness, do you mean bypassing the huge distance of wiring and going from point A to point B directly? (Wherever it connects to the controller and then go directly to the glow plugs) is there a guide for this?
oilhammer
Technical Service Bulletin
The engine harness goes to everything on the engine, up through the holder under the air cleaner area, into the cowl, to the ECU.
However, the glow plug connectors with pigtails are available by themselves that can be [properly] spliced in, and that often is all that is needed.
The part number for these individual ones is: 03L-971-785-A and they serve ONE plug.
kruxpavilion
Canada
Thanks so much for that information! I guess the only issue is figuring out where exactly they connect to the ECU
JELLOWSUBMARINE
yes
Thank you
I had a similar issue? CEL initially came on when weather cooled and semi cold engine was stressed getting on the freeway. My generic code reader only read the codes 1 out of 4 times before clearing the CEL. The codes were P13CE & P13DO. The repair was covered under warrenty. Codes were for pressure sensor related issue #1 cyl. The #1 glow plug cured it.
Youtube has some good info on testing the glowplugs
kruxpavilion
Canada
I guess I'll just have to test all of them before I do anything else, honestly. I suppose a short on one of the plugs can cause the others to detect a bad connection..
JELLOWSUBMARINE
yes
FWIW somewhere I read the cjaa has a pressure sensor/glow plug in all 4 cylinders. Other TDI engines (I forget which) have glow plug with pressure sensors on 2 and glow plugs only on other 2.
kruxpavilion
Canada
I'll do a VCDS test tomorrow - and post the error codes and hopefully we can clarify any doubts or questions we have about what my model is... Exact error codes, etc.
kruxpavilion
Canada
Alright everyone. Here's my log. There are quite a few errors. Let me know if anybody has any ideas!
Monday,17,February,2020,11:03:20:28922
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64)
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: 3VWML7AJ5CM605736 License Plate:
Mileage: 170750km-106099mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWML7AJ5CM605736 Mileage: 170750km-106099miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 D HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H14--- Serial number:
Coding: 0350072
Shop #: WSC 03777 002 1048576
VCID: 2F43E1EBBE6DB6370C-807A
12 Faults Found:
005072 - Cylinder 1 Internal Pressure Sensor
P13D0 - 003 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100011
Fault Priority: 2
Fault Frequency: 54
Reset counter: 255
Mileage: 164005 km
Time Indication: 0
Date: 2014.05.15
Time: 19:54:14
Freeze Frame:
RPM: 1472 /min
Speed: 73.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 50.0 bar
(no units): 7.10
Ign. Timing: 0.9 °BTDC
(no units): 3.60
005079 - Cylinder 4 Internal Pressure Sensor
P13D7 - 000 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 102
Reset counter: 255
Mileage: 164004 km
Time Indication: 0
Date: 2014.05.15
Time: 19:52:56
Freeze Frame:
RPM: 1771 /min
Speed: 70.0 km/h
Bin. Bits: 00000010
Absolute Pres.: 243.0 bar
(no units): 12.70
(no units): 8.40
005073 - Cylinder 2 Internal Pressure Sensor
P13D1 - 000 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 101
Reset counter: 255
Mileage: 164004 km
Time Indication: 0
Date: 2014.05.15
Time: 19:52:56
Freeze Frame:
RPM: 1633 /min
Speed: 96.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 232.0 bar
(no units): 2.10
(no units): 4.40
005070 - Cylinder 1 Internal Pressure Sensor
P13CE - 000 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Reset counter: 255
Mileage: 164004 km
Time Indication: 0
Date: 2014.05.15
Time: 19:52:56
Freeze Frame:
RPM: 1633 /min
Speed: 96.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 189.0 bar
(no units): 12.70
(no units): 3.60
005076 - Cylinder 3 Internal Pressure Sensor
P13D4 - 000 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Reset counter: 255
Mileage: 164004 km
Time Indication: 0
Date: 2014.05.15
Time: 19:52:56
Freeze Frame:
RPM: 1633 /min
Speed: 96.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 144.0 bar
(no units): 0.50
(no units): 10.40
005081 - Cylinder 4 Internal Pressure Sensor
P13D9 - 003 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 255
Mileage: 164005 km
Time Indication: 0
Date: 2014.05.15
Time: 19:53:57
Freeze Frame:
RPM: 1656 /min
Speed: 98.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 58.0 bar
(no units): 8.20
(no units): 8.40
005078 - Cylinder 3 Internal Pressure Sensor
P13D6 - 003 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 50
Reset counter: 255
Mileage: 164005 km
Time Indication: 0
Date: 2014.05.15
Time: 19:54:13
Freeze Frame:
RPM: 1334 /min
Speed: 17.0 km/h
Bin. Bits: 00000010
Absolute Pres.: 231.0 bar
(no units): 0.90
Ign. Timing: 0.5 °BTDC
(no units): 10.40
005075 - Cylinder 2 Internal Pressure Sensor
P13D3 - 003 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 55
Reset counter: 255
Mileage: 164005 km
Time Indication: 0
Date: 2014.05.15
Time: 19:54:19
Freeze Frame:
RPM: 1633 /min
Speed: 43.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 0.0 bar
(no units): -12.80
(no units): 4.40
001699 - Sensor Reference Voltage "D"
P06A3 - 000 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 255
Mileage: 164155 km
Time Indication: 0
Date: 2014.05.17
Time: 21:09:54
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Temperature: 39.6°C
(no units): 0.0
Torque: -150.0 Nm
P13D6 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 167367 km
Time Indication: 0
Date: 2014.06.16
Time: 00:42:36
Freeze Frame:
RPM: 1403 /min
Speed: 55.0 km/h
Bin. Bits: 00001011
(no units): -12.80
Ign. Timing: 8.6 °BTDC
(no units): 10.40
P13D9 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 167367 km
Time Indication: 0
Date: 2014.06.16
Time: 00:42:36
Freeze Frame:
RPM: 1403 /min
Speed: 55.0 km/h
Bin. Bits: 00001011
(no units): -12.80
Ign. Timing: 3.1 °ATDC
(no units): 8.40
P13D3 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 167367 km
Time Indication: 0
Date: 2014.06.16
Time: 00:42:36
Freeze Frame:
RPM: 1403 /min
Speed: 55.0 km/h
Bin. Bits: 00001011
(no units): -12.80
(no units): 4.80
Readiness: 1 9 0 0 1
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C492200FF881206E7921F0042310000
Shop #: WSC 00066 000 00000
VCID: 7BDB05BBFA959A97F0-802E
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
Shop #: WSC 00066 000 00118
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 002172579B73F94FA5-8054
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 L HW: 5K0 937 086 L
Component: BCM PQ35 M 011 2048
Revision: BJ011001
Coding: 2D380E1A802F3EC4008000817000054441000086535D0560648020200040
VCID: 3D5FCBA3A40154A78E-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 06071 26 0512
Coding: 009795
1 Fault Found:
02394 - Parking Light Left Front (M1)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 34
Reset counter: 130
Mileage: 163957 km
Time Indication: 0
Date: 2014.05.14
Time: 02:27:50
Freeze Frame:
Term 15 Off
Voltage: 12.90 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA00KF-
Coding: 00003134
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FA3B1ABA60D46B79C-806A
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1C0D245EZZZ1
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME3B31365EZZZ/
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME586A1D27ZZZX
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME5B603F27ZZZV
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME1B692327ZZZH
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME2C612327ZZZC
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AT HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KDJ000FK
Coding: 1080140000
Shop #: WSC 00066 000 00186
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 0225785F957FEB5FB3-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 862 A HW: 5K0 920 862 A
Component: KOMBI H32 0305
Revision: X0032006 Serial number:
Coding: 370D20
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2C79F6E7477BCD2F29-8078
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 08071101270298
Coding: 352002
VCID: 354FD3839C318CE746-8060
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 920 862 A
Component: IMMO H32 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6AF530FF8D0F131F1B-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0002538206
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5B9B653B52557A9790-800E
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005678096
Coding: 000490
1 Fault Found:
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 119
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 3449EE87574B95EF71-8060
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0002488367
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5C996627575B7DAF99-8008
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005698518
Coding: 000490
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 125
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0004
Revision: -----03S Serial number: VWZ4Z6L3155980
Coding: 05000400040007
VCID: 236B1DDB22A5025798-8076
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 10
Mileage: 163644 km
Time Indication: 0
Date: 2014.05.13
Time: 22:41:40
End-------------------------(Elapsed Time: 02:30)--------------------------
