Old February 14th, 2020, 14:29   #1
verdigo
TDI(s): 98 Jetta
Fuel Economy: 39-45
Default 98 Jetta AHU Stalls and then re-starts
So like the title says it stalls. This happens when under a moderate load but definitely when I stick my foot in it a little bit. I could even say under normal driving. As soon as it stalls all I have to do is cycle the key even without going to the start position and operating the starter. While it is coasting down still in gear with the engine turning, I just cycle the ignition switch to off and back to run and it picks up. I am guessing maybe the shutoff valve/switch on the pump. It only has a half million miles on it though. What do you guys think?
Dennis
verdigo is offline   Reply With Quote
Old February 14th, 2020, 14:33   #2
Steve Addy
TDI(s): 97 Mk3
Dennis
Any CEL from this activity?
Steve
the magic triangle spins in the peanut and then apex seals come out
Strava
Old February 14th, 2020, 15:51   #3
ToddA1
Fuel Economy: Dismal
Something is triggering limp mode and cycling power clears it, until the ecu sees the fault again. If it’s not triggering a CEL, scanning the car will usually find it.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old February 14th, 2020, 18:11   #4
Mongler98
scan for codes. report back
2010 Jetta TDI starts, then stalls Smashed Ixnay VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 23 January 8th, 2016 02:03
06 Jetta tdi starts/stalls out kcjettaman TDI 101 0 February 24th, 2012 10:13
98 Jetta AHU - Running pretransplant - Post Install it starts rough and dies in 3 sec int76 TDI 101 1 December 29th, 2011 19:08
Car stalls, starts after bleeding injectors but then stalls again uncah91 TDI 101 4 November 7th, 2011 21:33
1998 jetta starts then stalls makejettago TDI 101 18 September 10th, 2006 18:19
Page generated in 0.13352 seconds with 12 queries
[Output: 63.55 Kb. compressed to 57.03 Kb. by saving 6.52 Kb. (10.26%)]
