Hi guys
I have a bad problem with my 2011 Q5 3.0 TDI with 26,000 miles. Everything works fine but engine won't start. As I turn ignition, the starter does its work but nothing happens.
I've looked through VCDS but there is absolutely no DTC error code. As battery ran out there appeared so many errors relating to Voltage appeared but I cleared them all.
Is there any common fault with these diesel engines? We do not know what to do.
- Fuel pump does work and rail have pressure.
- I can see combustion gases coming out from muffler and also from air intake.
- NO DTC error codes.
Any clue, guys?
Thank you in advance.
Any clue, guys?
