2005 Passat PD BHW I changed fuel filter, I did not fill with fuel, big mistake. I started it and it ran 2 minutes checked for leaks none. turn off key. cleaned up. tried to restart, no start. cycled sw 8 times. no start. connected VCDS Basic setting group 035 turn on the fuel pump cycled it 8 times. cranked no start. cranked 20 seconds and STOP appeared on dash. oil pressure I think? it wasn't on long enough to read. can I verify fuel thru injectors with VCDS while cranking? no trouble codes. It has always started in the first 3 seconds of cranking in the past. I just changed oil and started it up and ran for 5 minutes checking for leaks. Installed skid plate. then changed fuel filter. Could I have washed down the cylinder with fuel and lost compression?
Thanks for the help. Lloyd
