Laser Key Cut around Hamilton/GTA
Strider17
Hamilton, Ontario, Canada
Beetle(sold) MK4 Golf TDI(sold) Mk4 Jetta TDI(parted out) MK4 Golf GTI w/ALH swap (built then parted out) 2015 Passat TDI Highline (current)
Strider17
there is a guy in cambridge i believe. found him on kijiji. just waiting for my blank key to come in.
looks like he can program the 2009 push in key type cars too. b6 passat
dmp
Toronto
15 Golf, 13 Golf (for sale)
replied to your pm, sorry I didn't get back to you earlier.
danielsza
Mount Hope, Ontario
2014 Passat TDI 6 Speed Manual, Highline, no sports package, Night Blue Metallic
I can cut them at work.
We charge $15 plus HST to cut the keys.
We are in Hamilton.
yhmtdi
Ancaster, Ontario
'01 Golf TDI, '00 Golf 1.8T
Is there a business name, and where are you in Hamilton?
I'd like to get some spare keys cut for my cars too.
Mark
danielsza
Mount Hope, Ontario
John Bear Buick
1200 Upper James st. Hamilton
Upper James & the linc
The only keys I can't cut are the outside laser cut, like a Pontiac G8 or Honda. All the others we can cut.
Strider17
John Bear Buick
i used to deliver parts there when i worked for upper james toyota. how much to get the key cut @danielsza
imo000
Cambridge
2009 M-B ML320 Diesel & '05 Passat TDI Manual 5-Speed
Are they really laser cut or just milled but people call them laser cut? The tooling marks looks milling to me.
dmp
Toronto
They're milled. The 'laser cut' is simply that each cut is done straight from pitch to pitch instead of a consistent angle like a lot of other keys. This is to keep the wear down on the more complex locks.
It was a term that just caught on early on. Another name that seems to be more appropriate is 'sidewinder keys'.
Source: I do some work in auto locksmithing
Strider17
Went to John bear Buick. They said they can’t cut VW keys cause the Passat key is plastic
Windex
Cambridge
05 B5V 01E FRF
The newer GM keys are same switchblade design "made of plastic" as VW keys. How do they cut those?
*headscratcher*
Strider17
the passat keyblade is made out of hard plastic.
the picture above, the keyblade is made out of metal, and the fob made out of plastic
Windex
Cambridge
05 B5V 01E FRF
got it - one of the newer ones where the blade is rarely used.
I would think that milling plastic would be even easier?
Strider17
No idea. I would think so too.
I just think the guy has never done anything like it and didn’t want to experiment.
danielsza
Mount Hope, Ontario
I'm not sure why they said that, come see me Daniel in parts and I will cut it for you.
Windex
Cambridge
05 B5V 01E FRF
Tell him that Adam, the sarcastic apprentice from the early nineties says hi.
igiveup
Mississauga, Ontario
2005 Passat, 2009 Jetta
Would any GM dealership be able/willing to cut a VW key? I just spent 15 minutes on hold with my local GM dealer before I gave up on them. Maybe best to take a drive by.
igiveup
Went down to John Bear today, had a couple keys cut.
They gave me a 4 digit number with the key. Any chance this is the immobilizer code?
I didn't think they could figure that out just from the key.
danielsza
Mount Hope, Ontario
The code you would have been given was your key code.
You can use the key code to have another keycut without tracing the old key.
