mogly
Good morning I’m new to this site and toVolkswagen Engines in general I have worked on many marine diesel engines varying sizes from alcove to Fairbanks to cummings to Detroit diesel so I have experience working with Diesel engines. I bought a catamaran with two Volkswagen 2001 TDI ALH engines I have read through most the discussions on engine marinization and their very interesting.
I have overheating issues with one of the engines and was looking for some advise as to what to look for. When I bought the cat neither engine had thermostats in I installed 180 stats one engine does well and holds at about 185 constant. The other comes up to 185 and then after about 30 minutes continues to climb and go all the way up to 220 i back down and it will most times cool back down to 185. I’ve cleaned the raw water heat exchanger and have a good flow over the side. this is running at about 2000 RPM. Any sujestions
Interesting. Are these factory marine TDIs? Pics would be cool.
As for your overheating. I would highly recommend using IR gun. Spend some time in the engine compartment and compare between the normal operating temp engine and this hot unit. You should be able to narrow down relatively quickly where the heat is being generated.
