calimustang
- Joined
- May 17, 2010
- Location
- Central FL
- TDI
- 2011 JSW DSG (buyback, RIP), 2014 JSW TDI, 2015 Passat TDI, 2013 Jetta TDI.
Hello,
heres the codes pulled out.... the dreaded P0841.....
when i go WOT, i could feel slipping a bit. has been feeling that since she turned 200k miles, now 282k.
as of lately right now when its cold, it gets stuck in first gear until halfway warmed up, it starts to shift normally. its been doing that for about a year if left sitting for a day or two. but now... I drove it on Thursday, just fine. then Friday, it did act up then warm up then go on (big busy highway) 441 and launch hard to 6th gear then suddenly drops to 3rd engine screaming. so i had to slow down, locks up into 1st... struggles to get into 2nd then drops to 1st gear.
Address 02: Auto Trans Labels: 02E-927-770.clb
Control Module Part Number: 02E 300 052 G HW: 02E 927 770 AL
Component and/or Version: L DSG AG6 511 2267
Software Coding: 0000024
Work Shop Code: WSC 01286 386 08256
VCID: 183FBB6D2B16AE84FF-804C
1 Fault Found:
17225 - Transmission Fluid Pressure Sensor/Switch 1
P0841 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 453098 km
Time Indication: 0
Date: 2025.14.20
Time: 16:50:25
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
Mileage: 453100km-281543miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: L DSG AG6 511 2267
Revision: 05151112 Serial number: 00001005151419
Coding: 0000024
Shop #: WSC 01286 386 08256
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 453098 km
Time Indication: 0
Date: 2012.10.29
Time: 16:50:25
Address 03: ABS Brakes (J104) Labels:. 1K0- 907-379-60EC 1F.clb
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B600C49220003880C06E892220042B70000
Shop #: WSC 00066 000 00000
VCID: 74E7AFDDD73E2AE433-8020
8 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 4
Reset counter: 114
Mileage: 442983 km
Time Indication: 0
Date: 2012.08.09
Time: 19:03:47
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 65
Count: 49664
Count: 1
Count: 1022
Count: 0
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 7
Reset counter: 147
Mileage: 446193 km
Time Indication: 0
Date: 2012.09.01
Time: 09:18:55
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 83
Count: 50944
Count: 61161
Count: 64520
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 52
Reset counter: 148
Mileage: 419308 km
Time Indication: 0
Date: 2012.02.17
Time: 12:19:37
Freeze Frame:
Count: 3
Count: 12
Count: 4096
Count: 128
Count: 42752
Count: 0
Count: 0
Count: 0
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 143
Reset counter: 108
Mileage: 418513 km
Time Indication: 0
Date: 2012.02.12
Time: 20:27:31
Freeze Frame:
Count: 16384
Count: 0
Count: 12800
Count: 72
Count: 49666
Count: 1
Count: 245
Count: 3584
Freeze Frame:
Fault Priority: 1
Fault Frequency: 20
Reset counter: 109
Mileage: 436885 km
Time Indication: 0
Date: 2012.07.04
Time: 08:37:49
Freeze Frame:
Count: 17472
Count: 0
Count: 12800
Count: 67
Count: 50176
Count: 258
Count: 756
Count: 2304
03841 - RPM Sensor Rear Left: Incorrect Signal
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 109
Mileage: 451208 km
Time Indication: 0
Date: 2012.10.14
Time: 11:38:57
Freeze Frame:
Count: 0
Count: 12
Count: 12800
Count: 71
Count: 50176
Count: 0
Count: 0
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Reset counter: 102
Mileage: 418513 km
Time Indication: 0
Date: 2012.02.12
Time: 20:27:44
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 16390
Count: 49921
Count: 65280
Count: 6
Count: 0
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 35
Reset counter: 107
Mileage: 436885 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 12
Count: 4096
Count: 80
Count: 40704
Count: 63488
Count: 0
Count: 0
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 0035
Revision: BG011001
Coding: 2D380E1A902F3EC400080081600000C401000086535D8560648020000040
VCID: 34676FDD97BE6AE4F3-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 21071 23 0512
Coding: 009795
6 Faults Found:
00984 - Left Tail Light (M4)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 128
Mileage: 448932 km
Time Indication: 0
Date: 2012.09.25
Time: 12:20:16
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
00987 - Lamp for Brake Light; Left (M9)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 1
Fault Frequency: 1
Reset counter: 128
Mileage: 450874 km
Time Indication: 0
Date: 2012.10.12
Time: 10:55:18
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 128
Mileage: 451643 km
Time Indication: 0
Date: 2012.10.16
Time: 15:55:34
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
OFF
OFF
ON
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 128
Mileage: 448932 km
Time Indication: 0
Date: 2012.09.25
Time: 12:20:15
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
OFF
OFF
ON
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 128
Mileage: 448932 km
Time Indication: 0
Date: 2012.09.25
Time: 12:20:17
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 128
Mileage: 448398 km
Time Indication: 0
Date: 2012.09.19
Time: 14:02:23
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00H9PB
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 39795EE9B8DC978C20-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005BWXQ00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME76622453ZZZS
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME6D780553ZZZ+
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME0B1E4C21ZZZQ
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME3A524921ZZZI
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME10596520ZZZ4
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME5B666520ZZZI
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Reset counter: 109
Mileage: 418513 km
Date: 2017.09.21
Time: 20:27:47
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001214528
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 275D88915E68117C46-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005108461
Coding: 000490
2 Faults Found:
132610 - Motors for Rear Central Locking
B122C 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 452691 km
Date: 2018.06.04
Time: 17:45:51
132866 - Switch for Rear Central Locking
B122E 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 452691 km
Date: 2018.06.04
Time: 17:45:51
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 316966C9A8AC5FCC98-8064
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Reset counter: 109
Mileage: 453101 km
Time Indication: 0
Date: 2012.10.30
Time: 08:06:33
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 30.0°C
RPM: 819 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 453098 km
Time Indication: 0
Date: 2025.14.20
Time: 16:50:25
Coding: 0000024
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 453098 km
Time Indication: 0
Date: 2012.10.29
Time: 16:50:25
Revision: 00H30001
8 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 114
Mileage: 442983 km
Time Indication: 0
Date: 2012.08.09
Time: 19:03:47
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 65
Count: 49664
Count: 1
Count: 1022
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 147
Mileage: 446193 km
Time Indication: 0
Date: 2012.09.01
Time: 09:18:55
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 83
Count: 50944
Count: 61161
Count: 64520
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 52
Reset counter: 148
Mileage: 419308 km
Time Indication: 0
Date: 2012.02.17
Time: 12:19:37
Freeze Frame:
Count: 3
Count: 12
Count: 4096
Count: 128
Count: 42752
Count: 0
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 1
Reset counter: 108
Mileage: 418513 km
Time Indication: 0
Date: 2012.02.12
Time: 20:27:31
Freeze Frame:
Count: 16384
Count: 0
Count: 12800
Count: 72
Count: 49666
Count: 1
Count: 245
Count: 3584
Freeze Frame:
Fault Priority: 1
Fault Frequency: 20
Reset counter: 109
Mileage: 436885 km
Time Indication: 0
Date: 2012.07.04
Time: 08:37:49
Freeze Frame:
Count: 17472
Count: 0
Count: 12800
Count: 67
Count: 50176
Count: 258
Count: 756
Count: 2304
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 109
Mileage: 451208 km
Time Indication: 0
Date: 2012.10.14
Time: 11:38:57
Freeze Frame:
Count: 0
Count: 12
Count: 12800
Count: 71
Count: 50176
Count: 0
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 2
Reset counter: 102
Mileage: 418513 km
Time Indication: 0
Date: 2012.02.12
Time: 20:27:44
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 16390
Count: 49921
Count: 65280
Count: 6
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 35
Reset counter: 107
Mileage: 436885 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 12
Count: 4096
Count: 80
Count: 40704
Count: 63488
Count: 0
Count: 0
Revision: BG011001
Coding: 009795
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 128
Mileage: 448932 km
Time Indication: 0
Date: 2012.09.25
Time: 12:20:16
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 128
Mileage: 450874 km
Time Indication: 0
Date: 2012.10.12
Time: 10:55:18
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 128
Mileage: 451643 km
Time Indication: 0
Date: 2012.10.16
Time: 15:55:34
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 128
Mileage: 448932 km
Time Indication: 0
Date: 2012.09.25
Time: 12:20:15
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 128
Mileage: 448932 km
Time Indication: 0
Date: 2012.09.25
Time: 12:20:17
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 128
Mileage: 448398 km
Time Indication: 0
Date: 2012.09.19
Time: 14:02:23
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Coding: 00003044
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 109
Mileage: 418513 km
Date: 2017.09.21
Time: 20:27:47
Coding: 0004B5
Slave Driver:
Coding: 000490
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 452691 km
Date: 2018.06.04
Time: 17:45:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 452691 km
Date: 2018.06.04
Time: 17:45:51
Revision: 00H17000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 109
Mileage: 453101 km
Time Indication: 0
Date: 2012.10.30
Time: 08:06:33
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 30.0°C
RPM: 819 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
