nicholai
Great writeup! Just what I needed!
you need a NEW vise grips tho--as theres very little shoulder for it to catch on--Raber said:Thanks kooyajerms!
For the excellent photos.
Really helped cut down on the anxiety level
when replacing the switch!
I used a vise grips on the collar and pulley puller
to pull the collar. - Which worked well.
Thanks for taking the time to take and post photos.
Very helpful!
much easier with the vise grip method--kooyajerms said:Glad that worked out for you. Yes, I have more tools 3 years later. I would rather have cut the collar off and put a new one =)
The lock cylinder housing is made of zinc. You have to drill a hole in the 'exact' spot so you can use your drill bit to push in a spring loaded locking pin which releases the lock cylinder. With the locking pin pushed in the cylinder is released and slides right out.DieselmannG said:hey guys i have my column out. My ignition switch was bad, but my son broke the key off in the lock cyl.!!?? But i need to know how to remove the lock cylinder from the housing??? Anyone please help me out.
Thanks guys.
The 'preferred' way to seat the collar is to take the large nut that holds the steering wheel and use that to press the collar back onto the steering column. This is done with the steering wheel OFF the steering column, the nut is pressed directly against the collar. Then remove the nut and install everything as usual. It's actually a very smooth operation.tdidieselbobny said:Ok, this question is for the people who have done the switch by removing the adapter collar-when you put the collar back on, is it safe to smack it back on w/hammer and block of wood? I just bought a small puller today,and will be doing it later tonight.Does it go back on easily,or does it take a bit of force? I just don't want to go too berserk w/ it and end up w/ problems w/ rack or u-joint from banging on the end .....
