pharmgdb
- Joined
- Sep 2, 2006
- Location
- Broussard, LA
- TDI
- 2005 2500 GMC Duramax; would like to upgrade my wife to diesel
Page 9 #3 states:
3. B100 is not compatible with some hoses and gaskets. B100 may soften and degrade certain types of rubber compounds found in hoses and gaskets (i.e. buna N, nitrile, natural rubber) and may cause them to leak and become degraded to the point they crumble and become useless. This could cause a fuel spill on a hot engine, could ruin a fuel pump, or could result in filter clogging as the hose material gradually wears away. If using B100, extreme care should be taken to ensure that any part of the fuel system that touches the fuel is compatible with B100. Some systems already have biodiesel resistant materials (i.e. Viton™) but many do not because these materials are usually slightly more expensive.
I thought Buna N and Nitrile were fine for biodiesel. I did some searches and recently there was some mention of not the compatability but the heat causing failures with these compounds. Any uptoday information on this?
